? on oil change
? on oil change
did an oil change yesterday put the oil in, ran the truck shut it down waited 5-10 min checked it and it was about half on the stick so i through another quart or so in in and it was right at the top. checked the truck today make sure every thing was good no leaks checked the oil and it was about a 1/2in above the full line so no its over full. should i drain it out or just leave it alone?
Drain out some. i always pour the amount it takes...like 11.38liters and the dipstick always reads below the low mark so i always add an extra quart, in the morning when i check the iol it always between the low and full mark. talked to a tech about it they said its safe to add oil just not to let it pass the full mark on the dipstick
I'd leave it alone. Since you've changed the oil, there's probably been a regeneration event of the DPF. The end result of this process is that a very small amount of fuel ends up in the crankcase for each event. If you were to drain the oil to the full mark, you would be causing the amount of fuel in the crankcase in the future to be of an even higher concentration, as with each event, more fuel is added. Makes sense? If you decide that you want to drain the excess just to fail safe, what you should do is drain it till it's below the full level, then top it off with new oil, thereby increasing the oil/fuel mixture in the crankcase. I've talked to more than one tech, and in each case they've said that these trucks can run with the level above the full mark on the dipstick with no ill effects. Again though, it's your truck so you should do whatever it is that makes you feel best.
I think that with the drain plug located in center of the bottom of the oil pan as it is, what happens in the vast majority of cases is that unless the truck is perfectly level, not all of the oil is drained out of the pan when we change our oil... another reason for so many owners experiencing an over-full condition. Just my .02....
Absolutely correct.
Yep. I always drive mine 20 minutes,let it drain for 15,remove the filter and reverse the process. I fill the oil filter and the balance goes in the engine per Cummins instructions. I changed it @ 5,000 miles and Blackstone let it go to 6,500 next time so will do.
Oil is oil weather it be pints quarts or gallons! But if your going by size I got y'all beat! Hehehe. But yeah you should drain some .50" is alot past full in my opinion. Manual says Do not overfill or seriuos dmage can occur. But who knows.
Not sure how much extra it takes on these motors but too much oil can be VERY bad. If the crank is able to slap the oil it will cause it to foam making it nearly impossible for the pump to pick it up and distribute it to the motor properly. Drain it down to the correct level. Next time you fill it up just dump the 3 gallons in and let it sit, it will eventualy catch up.
I've found it can take 30 minutes before all of the oil drains back to the pan so if I want to check the oil level I let it sit over night if I want an accurate reading.
For what it's worth, i've over filled mine atleast 1/2" over full on many occassions and never had a problem.
If it were MY truck, i wouldn't worry about it.
But that's just my oppinion.
IT does not matter what oil you use, when the crank is spinning as fast as it is, if it continueously slaps the oil, it will foam. Some oils may foam less then others, but all of them will foam. There is no way around it, it's air being introduced into the fluid.
