Need help starter issue..
Old Nov 30, 2017 | 11:23 AM
Anthony Strunk's Avatar
Angry Need help starter issue..
I have an 08 2500 6.7l . It had been starting and running flawlessly but I went to the auto parts store the other night turned it off and when I came out 10 min later and tried to start it everything looked normal but when I turn the key to engage the starter it trys to start for 1 second then stops for 1 second and continues this 3 times before it completely stops and I have to recycle the ignition switch.. luckily the engine was warm so it fired up but now after it has set all night it doesn't turn over enough to start.. any suggestions?
Old Nov 30, 2017 | 12:43 PM
marathon's Avatar
Batteries and cable connections.
Old Nov 30, 2017 | 09:49 PM
I put new batteries in 3 months ago..theyre not the problem it cranks normal but only for a second then stops then starts then stops 3 times then nothing until I cycle the key switch..i cleaned the cables a month ago... that's not the problem either..
Old Nov 30, 2017 | 09:52 PM
Starter sounds normal no weird noises. No codes I'm at a loss here.. could it be the starter solenoid? Starter wire? Starter relay if it has one? Someone has had to have had this issue before..i would appreciate any input ..
Old Nov 30, 2017 | 11:35 PM
deere country's Avatar
Batteries can go bad at only 3 months of age. Sounds more like a possible starter issue to me. Take the starter lead off the starter and run a jumper wire direct from the battery to the starter. Make sure you have a wire the same size or larger than the factory wire, also make sure you have a good connection at the battery when trying this.
Old Dec 1, 2017 | 10:01 AM
I'll try that and give an update.. thank you!
Old Dec 1, 2017 | 07:29 PM
BarryG's Avatar
Could also be the starter contacts inside the solenoid for the starter. LarryBs sells new contacts for reasonable price if that is the issue
Larryb - LarryB's Starter solenoid Heavy Duty Rebuild kit for Dodge Cummins Denso 89-2006
Old Dec 2, 2017 | 03:13 PM
I called several dealerships and none of the mechanics had ever seen this issue..ill try the contacts thanks
Old Dec 5, 2017 | 12:04 AM
Turns out that a random bolt had gotten lodged between the solenoid contact and the starter housing. When I removed the bolt it was welded to the contact and tore it off as well.. so 1 new starter later my truck starts perfect again.. thank you all for the responses.
Hothead2500
15
Sep 6, 2012 08:26 AM
FMB
Nov 14, 2010 09:09 PM
buckman361
Nov 13, 2008 09:54 AM
Paradise Racing
Jan 18, 2005 09:08 AM
DDysput
May 5, 2004 07:44 AM
