Just got my 1st diesel and have some questions...
Old Nov 19, 2007 | 04:30 PM
kite_tmr's Avatar
Just got my 1st diesel and decided to join this forum to start learning. My prior vehicle was a 370whp 410t 4 cylinder Subaru wagon.
I bought a BIGHORN 2500 with the 6.7 liter. All recalls (as of Friday) are done and the truck runs like a champ (700miles so far). Started out getting around 12mpg and now i'm seeing 15.5 on the overhead (accurate?).
A few things i'm interested in and am hoping to learn in this thread:
1. I'd like to level the truck but want to keep a stock (feeling) ride and dont want to void warranty. Are just spacers ok?
2. i'm looking at different wheels, if i do a 2 inch leveling kit what size wheels/tires do most run?
3. When using the block heater, how many hours is too much? what outside temp justifies using it?
4. Do you think alternative fuels (diesel) will be available for us anytime soon?
5. Whats up with idling these rigs?
6. Anyone using engine management on the 6.7's yet? Do they leave evidence on the ECU after being removed?
On the Subaru forums i frequented i was one of the older members who bashed threads like this (lol). If that is you here, feel free to use sarcasm or feel free to give your opinions on any of the topics i have mentioned.
Any info or suggestions/comments will be greatly appreciated...
I will also search threads for these topics.
Old Nov 19, 2007 | 05:55 PM
dieseldan07's Avatar
[QUOTE=kite_tmr;1798339]5. Whats up with idling these rigs?
idling causes clogging of the dpf (diesel particulate filter) more frequent.
Old Nov 19, 2007 | 06:16 PM
white250005's Avatar
HEY MAN I WAS JUST GONA HELP YOU WITH SOME OF YOUR QUESTIONS I HAVE 17'S AND 35'S WITH NO SPACERS. i DONT KNOW MUCH ABOUT THE BLOCK HEATING. THE IDLING IM NOT SURE ABOUT EITHER BUT ON MY 5.9 MY TRIPLE DOG HAS AN IDLE UP OPTION ON IT WHICH IS PRETTY NICE. i LOOK AROUND A LITTLE BIT ABOUT THE 6.7'S AND I THINK THAT BULLY DOG HAS SOMETHING OUT AND I BELIEVE EDGE HAS SOMETHING OUT FOR IT ALSO
Old Nov 19, 2007 | 10:27 PM
kite_tmr's Avatar
Thanks fro the input. Hey WHITE, got any pics of your rig? I'd like to see it with the 35's...thanks
Old Nov 20, 2007 | 08:23 AM
sabersix's Avatar
Mine seems pretty accurate, but I never reset it. Accuracy seems better if you don't reset it. Try hand calculating to compare.
Sorry, don't know this one. I run stock wheels and it doesn't look unlevel to me.
I'd plug in below 20F. Heater draws 650 watts so you might want to get a timer. I use a timer to turn on 2 hours prior to leaving.
Don't know, but the 6.7L seems VERY sensitive to additives/fuel quality with the emissions filter. Be careful.
Latest flash is supposed to address regeneration while idling. You may also want to have the high idle feature enabled by the dealer. This lets you manually set idle speed between 1100-1500 with the cruise controls.
No idea. I run stock. Most (if not all) programmers leave some sort of footprint even if it is just something like number of starts being low.
Welcome to the forum! Enjoy the truck.
Old Nov 20, 2007 | 08:35 AM
2rowdy's Avatar
I installed mopar 988 springs. It stiffend up the ride a bit. Raised front end about 1 1/2"
I run stock so it will fit in my garage.
Never used block heater
Ecm records idling at 1100 rpm or less, so if dpf clogs up and the dealer decides excessive idling guess who foots the bill. Have you high idle enabled.
Supposedly smarty doesn't. I can't wait to get one.
Lots of reading available. Have at it.
Old Nov 20, 2007 | 08:45 AM
DaveB.inVa's Avatar
I know you guys are running 6.7's but my overhead is always between 8% and 11% high on the mileage.
Since you just got the truck, have some fun. Create an Excel spreadsheet to calculate your mileage. That way you can see trends through the life of the truck.
Old Nov 20, 2007 | 08:58 AM
kite_tmr's Avatar
Lots of good info guys, Thanks.
Machinos
Jul 1, 2010 09:05 PM
jcmoyer2004
May 29, 2008 05:06 PM
Ironforger
Introductions / New People
Feb 18, 2008 05:17 PM
tex23455
Sep 15, 2007 10:50 PM
bighogleg dodge
Aug 21, 2004 02:32 AM
