How many Quarts
If I just drop the transmission pan (aisin 6 spd)about how many quarts of trans fluid do I need.
Aso the front and rear diff.and the transfer case. Thanks in advance |
I dropped my pan and replaced both tranny filters and added 8 quarts of mopar ATF. I havent done my diffs yet.
Check your owners manual?
Buy 4 quarts for the rear, and 3 quarts for the front. Buy 3 quarts for the transfer case. You'll have some fluid left though.
aisin
Originally Posted by tnhtractors
(Post 2319063)
Go here http://www.amsoil.com/
On the right side go to the product lookup guides and select auto and light truck. Enter your info and it should have all of the fluid capacities for your truck. Hope this helps. |
Thanks for the info
Tree DR - I'am not sure, I gave the dodge dealer my vin # and they shipped me the two filters. How do I find out if I have an aisin tranny.
If you have a regular 3500 pickup (read: if your truck came with a bed on it) then you have a 68RFE transmission. If you have a 3500 Cab & Chassis then you have the Aisin automatic transmission. You have the 68RFE, tnhtractors.
Originally Posted by BroncoHound
(Post 2320593)
| All times are GMT -5. The time now is 08:13 AM. |
