Hissing sound from brake booster
Old 08-30-2013, 04:24 PM
Diesel fitter's Avatar
Wow I Haven't posted on hear in a very long time!
While towing my 5er the other day I started hearing a hissing sound, (seems to be near the brake booster) this did not affect my engine performance or brake performance. I did notice that I could change the sound by slightly turning the wheel or lightly stepping on the brake pedal. Sounds like some kind of vacuum leak, but doesn't this have a hydroboost system? Seems loudest coming right out of the pushrod area from under the dash.
Anyone else run into this before? I hope it is considered part of the power train warranty?
Thanks in advance!
Old 08-30-2013, 08:52 PM
willym's Avatar
Apparently (as I've read on other forums) there is a hose going to the brake hydroboost cylinder near the firewall that has a liner that gets loose and causes a hissing like noise as it restricts the oil flow. This may be your problem. Do a search here or on the Cummins forum for more info.
Old 08-30-2013, 10:15 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Replace the high pressure p/s hose from pump to hydro boost. Orifice tube inside hose breaks, causing noise in p/s system. easy to check remove the p/s line at booster top line. If the white plastic tube is stuck in the metal line then it has broken and needs to be replaced.
tt thomp (04-10-2019)
Old 09-02-2013, 12:29 PM
Thanks for the replies! Great info I will check that out thanks again!!!
Old 09-29-2014, 05:42 AM
RocknRick's Avatar
I guess it's my turn! Saturday I was cruising down the road and all of the sudden heard the dreaded "hissing" sound. It was like a vacuum line leaking. After 1 Google search amazingly DTR popped up with the answer. I just wanted to let everyone know how much I appreciate the communication on this Forum. I went from WT?, to replace the high pressure p/s hose. The new part# 68035282AF for the lower hose and part# 68080207AD for the upper hose, which is the hose with the plastic tube causing the hissing. Both hoses have had engineering changes, so I replaced them both. I hope the engineers got it right this time. Thanks Again
Rick
Old 12-14-2015, 02:59 PM
Well the hose made it a little over 2 years then failed again! So much for mopar fixing a design issue! Time for another $100 hose, I guess it could be worse!
Old 10-13-2018, 04:02 PM
Kenneth Mccall's Avatar
Hydraboost brake tube
I have 2009 cummins. My question pertains to the metal brake tube that enters the too of the hydraboost. Originally I had a small leak around the high pressure hose fitting coming from the power steering pump (at the power steering pump). I replaced the hoseand everythig seemed fine.
Later I started having the hissing sound, checked to see if it was the hose liner but the hose was intact. I replaced the hydra boost and that seemed to reduce the noise by about 50%, but about a month later a leak developed around the high pressure tube where it entered the hydraboost. When I removed the tube I found a hairline crack around the seating flange of the brake tube. I replaced the tube and everything seemed ok, no leak but still a little noisy until about 2 weeks later ... ling story short, I have now either replaced the tube myself or had a good diesel mechanic replace it 4 times total and the tube still continues to crack at the seating flange.
Has anyone else encountered this issue?
Is it common?
What is the cause?
MTC
09-09-2009 06:51 PM
Dodge@KY1997
04-30-2006 01:01 PM
RAM2940
10-30-2005 12:40 PM
Dave65
10-13-2003 05:10 PM
Clay
03-21-2003 10:53 PM
Quick Reply: Hissing sound from brake booster
