injector numbers
injector numbers
can somebody tell me what the difference in the injectors are between the 03-04, and the 04.5-07 trucks?
and what the numbers are for those years? part numbers? i have a set of cores, in which i will not be using, and i thought they were for a 03 truck, but i am not sure now.
The 03-04 have 018 stamped on the black plastic by the brass screws and the 04.5-07 5.9L have 032 stamped. If you look at the top of the injector with the screws at 6+12 o-clock then the # you are looking for will be at 2 o-clock or next to the top screw.
I hope this helps.
I hope this helps.
sCreamin400
11-02-2008 01:46 PM
durasmack
03-30-2006 07:49 AM
kawi600
03-04-2006 07:36 AM
