Engine Temps
Old 04-21-2019, 10:21 AM
dtenorio's Avatar
Engine Temps
My truck has no mods and I'm not towing, 180k miles. It used to run 200-210 all the time, now it seems to fluctuate 180~210, but on a trip with some hills leaving Phoenix, it ran up to 230 and started jumping higher then lower... I downshifted to keep the RPMs up, but hills are definitely affecting the temp (in a scary way). Also noticed engine was not responsive, power was low. Any ideas fellas? I had a CEL later in the trip, haven't checked it yet.
Thanks
Old 04-21-2019, 09:41 PM
johnh's Avatar
Replace thermostat
Old 04-21-2019, 09:52 PM
torquefan's Avatar
Usually, in the interest of keeping my vehicles reliable, I will throw in a new thermostat when I have the cooling system apart, like to replace the coolant, as it isn't a lifetime part. If yours is original, it's probably worth replacing it, hopefully it improves the condition. I would also take the hose and clean all the grime from the fins of the radiator.
Old 04-22-2019, 07:07 AM
Fordzilla's Avatar
And be sure that's the garden hose you use, and not the high pressure air hose...High pressure air can bend the fins of the radiator and block air flow...Don't ask how I know......Ben
Old 04-22-2019, 09:14 PM
dtenorio's Avatar
Picked up a thermostat today. On my way home, the temps dropped well below 170 when going downhill, looks like it's probably stuck partially open. I will update when I get it switched out. Thanks for the advice!!!
Dan
Old 04-23-2019, 01:53 PM
"California Style"
mega-engr's Avatar
Check the code for the CEL you got and let us know! Sometimes, the fan clutch can act up as well. Thermostat is good to change just in case as said all ready.
ellerman
06-09-2005 09:36 PM
CZSteve
05-21-2005 09:29 AM
angleiron
12-21-2004 01:13 PM
rico334
10-27-2004 06:49 PM
something87
08-25-2004 04:54 PM
Quick Reply: Engine Temps
