Engine oil temp monitoring?
Old Mar 16, 2011 | 06:35 AM
firestorm's Avatar
I am getting prepared to install my gauges, and looking for some help. I have an oil psi, which will tap into the oil filter housing. Fuel psi, will be installed post filter at the filter housing, with the help of a modified banjo bolt. My first dual gauge, is EGT ( pre-turbo)/ boost pressure. My second gauge is dual temp. I will be taping into the trans hot line for the first temp. Now comes the decision. Do I put a T at the oil filter, and monitor oil temp, tap the intake and monitor coolant temp, transfer case, or rear end?
Old Mar 16, 2011 | 08:57 AM
AH64ID's Avatar
Oil temp is on my list of want's, but so is rear diff/trans, etc. If your going to be towing heavy I say go with diff temp, as oil temp should follow coolant temp plus a bit.
Old Mar 16, 2011 | 09:26 AM
firestorm's Avatar
Right now, I don't do a lot of towing, at least anything the truck would consider 'towing'. A fifth wheel is in the plans, once we sell the house. How would you go about taping the rear dif, or is there a drain plug on the dif?
Old Mar 16, 2011 | 09:29 AM
klx650a2's Avatar
I heard oil temp is a pretty boring gauge to watch and some who had it removed it because it was so predictable. Mostly 5 to 10 degrees cooler than antifreeze.
Old Mar 16, 2011 | 09:30 AM
AH64ID's Avatar
Most aftermarket covers have a 1/8" NPT port. If you were to use the stock cover I would pull it and tap it if its thick enough, but you may have to have a bung welded on it.
MassZJ
Apr 24, 2011 06:46 PM
svtrich
Nov 17, 2007 06:33 PM
caseyclan
14
Apr 16, 2007 11:28 PM
Casey Balvert
Oct 11, 2004 11:24 AM
trailblazenyj
Jun 8, 2003 05:31 AM
