-   3rd Gen Engine and Drivetrain -> 2007 and up (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2007-up-114/)
-   -   Egr and cooler cleaning procedure (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2007-up-114/egr-cooler-cleaning-procedure-284851/)
cbrahs Feb 2, 2011 08:14 PM
1 Attachment(s)
I hope this works. Blake or any other admin, can you sticky this for members review so they can complete the process and save money?
Thanks
Chris
madhat Feb 2, 2011 08:22 PM
I got it for you, buddy. Good lookin out.
cbrahs Feb 2, 2011 08:38 PM
thanks guns!
mega-engr Feb 2, 2011 09:39 PM
Awesome! Thanks Cbrahs and Admins! Not only is this helpful to those in need, but also educations for those curious about the emissions in the engine compartment and/or looking to do this maintenance themselves in the future :cool:.
jswar Feb 3, 2011 08:33 AM
Gentlemen - Thank you!!
Navy7797 Feb 13, 2011 09:29 PM
??? confused
Now I'm confused, If deletes are done would you have to clean the EGR cooler and valve ? Nothing should be going through there I thought?
Is there some info on how to change the CCV filter ?
cbrahs Feb 14, 2011 09:11 AM
well if the egr and cooler are gone then they should be pretty clean already. this is only a procedure for STOCK trucks.
cbrahs Feb 14, 2011 09:17 AM
forgot to post reset procedure!!!!!!!!!!
ok forgive me but I forgot to add the reset procedure for the perform service light. SORRY!!!!!
PERFORM SERVICE INDICATOR - RESET The “Perform Service” message will display on the EVIC each time you turn the ignition switch to the ON/RUN position to indicate a emission maintenance is required. To reset the “Perform Service” indicator system (after performing the scheduled maintenance) refer to the following procedure: 1. Turn the ignition switch to the ON position (Do not start engine). 2. Press and release the brake pedal two times. 3. Fully depress the accelerator pedal slowly two times within 10 seconds. 4. Turn the ignition switch to the OFF/LOCK position. NOTE: If the indicator message illumination when you start the vehicle, the “Perform Service” indicator did not reset. If necessary repeat this procedure.
cbrahs Feb 14, 2011 09:19 AM
the ccv filter is easy, remove plastic outter valve cover. there are a few bolts holding the filter in place. remove filter and install new one and re-install valve cover. it is a 4 tenths hour job.
whiteeye42 Feb 14, 2011 09:27 AM
i tried to go to the link you have in the maintenance guide you posted the link is titled
see: Removal\Replacement\EGR cooler the link takes you to a site called alldatapro and you need a logon name and password to access it is there some way to bypass the logon and password because there is no way to access the info with out it
cbrahs Feb 14, 2011 09:30 AM
you can't click on the hyperlinks on the file that I posted unless you have log in access. i thought I removed them but looks like I didn't.
removal of the egr cooler is a 15mm wrench on the outside bolt, a 15mm socket with 3" extension reaching into between valve cover and cooler, a 11mm deep socket to remove v-band clamp, drain coolant. remove rubber hoses, pull cooler. its pretty simple
whiteeye42 Feb 14, 2011 09:45 AM
ok thanks
Navy7797 Feb 14, 2011 03:47 PM
Info
Thanks for the info cbarhs, thats what I needed to know.
jdinny Mar 8, 2011 07:39 AM
Great info
Semper-Fi
rpdsnow Oct 30, 2011 06:03 PM
[director]Thanks Chirs worked out good & saved a lot of money. Thanks again rpdsnow.
