Chevy 8 lug SRW on a Dodge SRW?
Old Nov 27, 2008 | 11:49 AM
Roger Portmann's Avatar
Anybody know if Chevy 2007 SRW 3500 wheels will fit a Dodge SRW 3500? I have a chance to get some Chevy Ricksons (19.5) but don't know if they will fit my Dodge. The wheels are in another city, otherwise I'd just try 'em on for size.
Thanks,
Roger
Old Nov 27, 2008 | 05:03 PM
mastercaster's Avatar
almost certain the bolt pattern is the same, but the hub is larger on the dodge. expect to pay in the neighborhood of $30 a wheel at a machine shop to have them bored out to spec.
Old Nov 29, 2008 | 09:31 AM
gtstrkd's Avatar
I have a set of pro comp wheels off of a 08 chevy and they bolted right up.
Old Nov 29, 2008 | 04:47 PM
MRoman's Avatar
The lug pattern is the same and the bore I think it is 5.15, more than enough to fit over the Dodge hub. The only problem may be with the offset. Have whoever your getting them from measure the offset and compare it to your wheels.
Mike
Old Nov 29, 2008 | 06:04 PM
yeah, i only know that on my 2007.5 dually, the everything was the same except the hub bore. i am certain of that. the dodge is 121.3mm and the chevyis 116.9mm.
Old Nov 29, 2008 | 06:07 PM
2500's Avatar
why don't ya call rickson's and find out for sure
http://www.ricksontruck.com/wheels_gm_srw.html
http://www.ricksontruck.com/wheels_dodge_srw.html
Old Dec 10, 2008 | 09:20 AM
04ctd's Avatar
i would think would be same as HUMMER wheels, most guys just use a die grinder to open up the center.
I "think" the HUMMER uses the same AAM axles as the GM 3/4 trucks,
and the ricksons are probably made generic enough to fit.
i bought some wheels that stuck out past the wheel well, and they kept the side of the truck NASTY, so that's a concern for the offset.
i finally took them off.
SRobertson
Feb 7, 2012 12:38 AM
dieselJon
Mar 6, 2008 04:58 PM
Tommy93w350
Aug 5, 2007 08:16 PM
Trebor
Sep 14, 2006 04:52 PM
95black2615
19
May 24, 2006 11:05 AM
