check engine light for egr wont go out
Well I unplugged the egr and all has been good for the year. I plugged it back in to get it to turn off . I did the 5 cycle over and over and it won't turn off and its been over 100 miles of driving .any ideas ?
just seen it at the top
From: This Nazi state of California 2nd home Gilbert AZ under God
I think it is a simple procedure. Just make sure you remove the motor before spraying and cleaning. Be also careful with the seals and you should be able to do this using cbrahs PDF.
.Or, delete it and get a programmer
.You probably need to be 100% stock all the time though?
ok well im still at it and this is an update . i removed the egr cleaned it out as required reinstalled it . i cleared the code and upon restart light cam back on the trouble code is p235b if i rememeber right it says egr not regenerated as many times as required? im guessing the code is saying i havent regen'd enough but *** do i do ? i have my apointment on monday but i would like to fix myself if possible ?
MOJO1
Aug 4, 2009 06:28 PM
choppers555
Oct 16, 2007 12:29 PM
alltimelow1
Apr 6, 2005 07:28 PM
