6 speed auto!! were does it get its readings??
Old Aug 24, 2008 | 08:06 AM
Racing_Joe66's Avatar
i am wondering were the new 6 speed auto gets its readings to run???? do any come from the engine n if so were?? also is the 6.7L bolt pattern on the rear the same as a 12V engine??
thanks
Old Aug 24, 2008 | 11:10 PM
BroncoHound's Avatar
I think (don't quote me on this) that there is a separate TCM that controls the transmission functions but i know it is also run somewhat off the PCM. That is why there are separate flashes on the '08s for the trucks equipped with manual transmissions vs. those that are equipped with automatic transmissions.
If you are thinking about a 68RFE swap into your 12V, i think ALOT of electronic adaptation would be necessary for it to run and shift right.
Old Aug 25, 2008 | 08:28 AM
yes i am looking at adapting one up to a 12V. will it bolt up??
thanks
Old Aug 25, 2008 | 01:42 PM
I honestly couldn't tell you. Im not an automatic guy. I honestly think that, for the money it would cost to secure a 68RFE and the electronics that go with it and adapt them to a 12v, whether a bellhousing adapter is needed or not, would cost a significant amount. Probably more than a bulletproof 47RE would cost you. Again, i can't say any of this with any kind of certainty, just my thoughts and guesses. Hopefully someone a little more in the know regarding automatic transmissions can chime in.
Old Aug 25, 2008 | 06:27 PM
XLR8R's Avatar
It shouldn't have a problem physically bolting up, but electronically...
Old Aug 25, 2008 | 06:40 PM
Dwitt0187's Avatar
someone get me the serial numbers off a 12v and a new 6.7 and ill check on our dealer access to cummins to see if i can match anything up that way
danny
Old Aug 26, 2008 | 09:23 PM
kblranch's Avatar
It will probably take one of the major aftermarket tranny people to come out with a "box" to get this to work.
olskooldodge
Jul 15, 2009 11:13 AM
zethtays
Dec 29, 2008 09:03 PM
PEAKSTRYDE
16
Feb 20, 2008 04:40 PM
haftrek
Nov 12, 2007 09:19 AM
ckennedy
Sep 27, 2004 11:58 AM
