6.7 vs. 5.9
So, I thought I'd be the 1st to post a question in this forum. Where are they getting the extra .8 liters from with the 6.7? Is it a different block, or did they just lengthen the stroke (and maybe enlarge the bore, too???) of the existing 5.9 that we all know and love? I appologize if someone has asked this before.
If it is the same block (or close to it), I wonder how long until someone puts 12v components onto one and sticks it into a 2nd gen. [coffee] |
i can see it now a p-pumped 6.7L cummins killing everyone at the pulls :D
They aren queezing it out of through the emisons control cram.
lgp9999:
You asked where Cummins is getting "the extra .8 liters from" on the new 6.7? According to their press reports on the new 6.7, the cylinders have been bored out some going from 4.02 on the 5.9 to 4.21 on the 6.7. Cummins also increased the stroke, going from 4.72 on the 5.9 engine to 4.88 on the new 6.7 engine. This all results in a displacement increase from 359 cid. on the 5.9to 408 cid. on the new 6.7. ------- John_P |
P-pumped 6.7, that's got a catchy sound to it. "I'm building a doomsday device and am going to aim it right up your hind knee!"
Originally Posted by rhino 660
(Post 1284180)
If you look hard enough.. you'll find some out there bigger than 408... (In a 5.9L block.) |
I wonder how much the fuel mileage is gonna drop over the 5.9? Makes you wonder why they went to the bigger engine. The 5.9 makes decent power so that isn't the reason for the step up.
(Post 1287619)
That's a good point especially considering how high fuel prices have been, anybody have an idea? What kinda mileage is the 6.7 supposed to get? |
(Post 1287619)
The way I understand it is a larger displacement engine can put out the same amount of emissions as a smaller one and be labeled as cleaner?[duhhh] Go figure, but I heard the 5.9 was having a hard time meeting the required emissions |
the 6.7L engine doesnt have to work as hard to make the same amont of power as the smaller 5.9L. thus equals lower combustion temperatures and lowers the nox emissions, thats the only reason for the larger motor to get the nox ratings to meet EPA specs. As far as the particle emmisions thats where the DPF comes into play to catch the soot. Wes
Thanks to everyone who answered my questions.
Hmm, if I ever win the lottery I may build me a 12v 6.7.[whistle] |
According to their press reports on the new 6.7, the cylinders have been bored out some going from 4.02 on the 5.9 to 4.21 on the 6.7. Cummins also increased the stroke, going from 4.72 on the 5.9 engine to 4.88 on the new 6.7 engine. This all results in a displacement increase from 359 cid. on the 5.9to 408 cid. on the new 6.7. 4.21 X 4.21 X 4.88 X 6 X .7854 = 407.59247Ci [duhhh] |
steelblitzkrieg:
For your information, I took those numbers from Cummins own literature, so if it is wrong then I would say it is on the Cummins literature. ------- John_P |
[duhhh][/quote]
John, Check your PM's I sent you a response.
