-   3rd Gen Engine and Drivetrain -> 2007 and up (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2007-up-114/)
-   -   6.7 interchangability.. (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2007-up-114/6-7-interchangability-321908/)
themagicman May 10, 2015 06:11 PM
Hello all, i have a question that I hope someone can answer. My 07 got ran out of oil and seized the crank, but later freed up and now has a rod knocking..only 75,000 miles on it..anyway my girlfriend(responsible party) is paying for new engine. We found on craigslist here locally a 6.7 that was used in a school for cummins techs..so has no mileage on it, just some run hours on stand...but here is my concern, iam wondering if cummins made a different 6.7 for like 18 wheelers, or other industrial uses. There is a tag on the engine that states 190 hp, and as you know the ram 6.7 is rated 350 hp. Also there are differences inthe intake manifold, exhaust manifold and the harmonic balancer....which i know can and will have to be changed. The exhaust has the turbo mounted right at the head between cylinders #3 and 4...Anyway does anybody know if this engine will work on my truck? I have serial number of engine and more that are on the tag...thanks all
themagicman May 10, 2015 06:33 PM
5 Attachment(s)
Attachment 44838
Attachment 44839
Attachment 44840
Attachment 44841
Attachment 44842
Here are pics of the engine I picked up today-does anybody know if it the same as a 6.7 that is in my 07 ram 2500?? Thanks
themagicman May 10, 2015 08:43 PM
Already did. I have been comparing images off the net of 6.7's and it looks like the l;ong block is the same, just all the bolt ons are different. Like the housing on back of the engine-bellhousing for lack od a better term, but it just bolts on the block, and same with the front cover that covers the cam drive is different, but I believe all my covers and intake, and exhaust, and oil filter housing etc will all bolt on-at least I hope so. If not it is a 3000.00 mistake...But this engine has zero hours on it..looking in the oil filler hole, and down the turbo all clean as a whistle....
patdaly May 12, 2015 08:03 AM
The HP rating will be whatever configuration he puts the engine in at, since he will pretty much require is old configuration to run, the HP rating will revert back to his stock HP.
mega-engr May 12, 2015 12:02 PM
Are the internal specs the same such as cam and timing?
themagicman May 13, 2015 03:21 PM
Yes I was thinking the same thing that the horsepower would be back to stock specs with my injectors, my computer, my intake system, my turbo and exhaust system...Figured all the heads, pistons and cams were the same...
themagicman May 13, 2015 08:46 PM
pull the cab??
I just heard from a diesel mechanic that you have to pull the cab off the truck to do an engine swap.....is that true?? Is there not anyway it can be done with the body in place??
patdaly May 14, 2015 07:53 AM
LOL, tell him it isn't a Ford 6.7 but a Dodge 6.7.
Fords you have to pull the cab to do just about anything....... Dodge it comes right out.
themagicman May 14, 2015 09:21 AM
Thank you!!
