4WD Shift Lever Hard To Operate
Old Apr 27, 2009 | 06:36 PM
mr. ed's Avatar
I've noticed that the shift lever to the transfer case has gotten pretty hard to operate recently. Perhaps it's because I don't shift into 4WD often and it's gotten stiff from lack of use. The other day I had occasion to use 4WD (low) and attempted to pull the lever back to 2WD. It took a lot of pulling to get it to work. I thought I would bust the lever doing so. Does the linkage need to be lubed? I'm going to have the local dealer look at it since I'm getting close to the 36,000 mile mark but I'd still like to get some opinions from you guys. Thanks...
Old Jun 10, 2009 | 03:17 AM
mybyke01's Avatar
Did you put into neutral first. I used to shut mine down with the shifter in netural and then put into 2wd but this is olny from 4wl. 2wd to 4wdh should be no problem but from 4wl it will be hard to move and will grind some if you don't shut it down.
Old Jun 10, 2009 | 07:41 PM
mr. ed's Avatar
I never heard of having to shut down the engine in order to shift from 4LO to 2HI. Anyway, I had the dealer look at it and it appears to be OK. I now believe that when I had difficulty shifting the lever the truck was still attached to the trailer and the wheels turned all the way. That may have put excess pressure on the drivetrain, thus making it almost impossible to shift. Just a guess...
Old Jun 10, 2009 | 08:45 PM
Hodge's Avatar
That may not be all you issue, but it is a large part of it. If you don't use 4WD much, the linkage can get stiff- it gets grime and junk on it. But, if you have been in 4WD, and don't move in the opposite direction to "unload" the drivetrain, naturally it will be very difficult to shift. Worse, you may get it shifted, but because of the pressure imposed, it may not disengage internally, and you can do serious damage if you proceed onto a hard surface. Reverse your direction 8 or 10 feet, shift out, and make sure it is disengaged. Either spin a tire to see, or you can steer sharp in one direction or another- you will load up the drivetrain and feel the resistance if it is still in 4WD.
Old Jun 11, 2009 | 06:59 PM
mr. ed's Avatar
Thanks for the info, Hodge....
RiverRat2
Jul 23, 2014 01:01 AM
rjweiss
Jan 31, 2013 01:23 PM
wrangler04
Jul 17, 2007 11:00 PM
Bad Ramer Jamer
Apr 17, 2006 07:41 PM
Greguw
Oct 24, 2005 10:08 AM
