Will a common rail run with out the lift pump?
The answer is yes and i saw it today! And i think on another thread i said i didnt think that it would, well now i stand corrected!
i drove over 50 miles with out one. then when i relized i had the fass unplugged i couldnt believe it myself. then the truck turned around and towed 10,000 plus pounds the night after then went on to put down 555hp and 1016tq on the dyno yesterday not bad for one weekend and a stock
cp3, clutch and turbo.
Another conformation that it will. I just found out that my lift pump wasnt working yesturday, it may have been out for a while. I will drive it this way until the new pump come in on Thurs.
As a long time gasser tech. I know that most rotating pumps love to push (water, fuel etc.) But hate to suck. Some mid 80's ford trucks had two pumps (one in the tank and one on the frame rail) Most newer cars have just a fuel pump in the tank. It is no surprize to me that it will pump without a lift pump. A full tank of fuel or a downhill pointing truck would help to get the fuel line primed for good enough operation. As to how much resistance there is in the fuel lines and lift pump to hamper flow for long term use. Who knows!
So the CP3 is sucking fuel?? I guess the only answer is yes. RobertP. -- or anyone else-- the reason I only got an xzt module is I didn't want to have to be buying a new clutch , driveline components etc etc. If I had known I could have all that power on stock stuff I wish I would have got regular 100hp box maybe I should sell it and get more powerful box
hitcb1789
May 25, 2010 09:10 AM
kyle_truck_pull
22
Jan 21, 2009 09:30 PM
