Who makes the best aftermarket ball joints
Im getting my front alxe ujoints replaced under warranty soon and I want to do the ball joints at the same time. I would like greaseable ones if possible OEM is not an option since they where gone at 50,000 mi.
Get the Moog's! Be sure you get the adjustable ball joints for the uppers! Just had them installed and the alignment came out dead on! The adjustable upper ball joints allow for camber adjustment, otherwise you don't have any camber adjustment.
Check out rockauto.com
They also have U-joints.
the uppers were $95 and the lowers were $91 total for all 4 were with tax was $407.95 ,they listed for almost $600 for the set .the adjustable moog I priced was 148 each.I choose not to go that route I do not have a lift and I run stock tires .
Big Bob is always right.
ks
Do a search on hear for Moog
Aftermarket Ball Joints
repeatGuys, Thought I'd post the part number for Moog Adjustable Upper Ball Joint for 03-05. Greasable, adjustable, and Moog. Part #K7448. I just replaced all ball joints at 131k miles for the first time. They weren't shot but they were on the way out and I did have a driver side Hub U-Joint gone so figured time to getter done. Could have gotten aftermarket lowers but the originals were still ok so why change when something works. All 4 were about $440. the Front Hubs were still good, not ok, but good...at 131k miles. I guess the moral of the story is don't pressure spray under the truck too much. My Poor truck is lucky if it ever gets washed and has only seen wax twice but the ball joints lasted well. ks
ksDo a search on hear for Moog
DBLR
Jun 20, 2014 02:51 PM
firebill1720
20
Mar 5, 2010 09:23 AM
getblown5.9
May 2, 2006 10:01 PM
Seeder
Feb 15, 2006 08:15 PM
