-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   When to change shocks??? (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/when-change-shocks-222841/)
kertoncol Nov 9, 2008 08:13 PM
I have about 148,000 miles and notice a clanking noise after I go over small bumps. Could this be the shocks??? Thoughts???
Looking at replacing all 4 with Bilstein's from Geno's. Good or bad?
megacabdad Nov 9, 2008 08:20 PM
The noise could be anything....
But 148K on stock shocks?
You are long over due if that's the case...
Bilstein's are a good choice.
bighornram Nov 9, 2008 08:24 PM
I usually plan on changing shocks with new tires if that helps. I will also be putting on Bilsteins when I buy my next set of tires.
kertoncol Nov 9, 2008 08:37 PM
Thanks for your help. I'll order them tonight!
38short Nov 10, 2008 07:30 AM
shocks
I've got over 170.000 miles on stock shocks. Are these gas charged??? I know I need some new ones .
D45 Nov 10, 2008 10:42 AM
The stock shocks typically last 35,000 miles.....
chadder1313 Nov 10, 2008 04:53 PM
Im having the same clanking noise going over bumps. Mine sounds like the exhaust being loose but ive checked almost everything under the truck and it almost has to be the shocks. Ive also got 54k on them. Let us know if the new shocks cured your problem.
kertoncol Nov 10, 2008 09:52 PM
The shocks are ordered! I'll let you know how if the noise is resolved and how I like them.
Thanks everyone...
Mlucas Nov 10, 2008 10:31 PM
the truck should be really "springy" if the shocks are blown. w/150, you may have ball joint issues...
SlowJeep Nov 11, 2008 07:23 AM
Hmmm... mine barely lasted 5000!
schv Nov 11, 2008 08:20 AM
I replaced my stockers with Bilsteins when the truck had only 3k miles, and the difference was incredible! Highly recommended!
D-Roc Nov 11, 2008 09:19 PM
Can Bilsteins be installed on a stock (ride height, and all stock suspension) truck? ANyone have part numbers for an 06?
ozpall Nov 11, 2008 09:26 PM
can anyone post how long are they compressed and fully extended?
thx
kertoncol Nov 11, 2008 09:40 PM
I believe the blue/yellow can be installed on the stock truck. That's what I bought. Take a look here for the part numbers.
D-Roc Nov 12, 2008 07:39 AM
Good stuff...thanks.
