whats the best tranny fluid to use ?
It's time for me to change my tranny fluid and I want to do the complete fluid exchange. Whats the best tranny fluid to use and does anyone know if NAPA sells a trannyfilter ? My nieghbor sells Royal Purple products. Is that stuff any good ?
Yes napa sells the filter. I like using Valvoline in all my fluids. You will get mixed reviews on RP and Amsoil. Personally I don't waste my money on them. They are over priced for what they do. Get your self some good Vavleoline, Castrol, Mobil ect fluids and you will be more than fine.
I use the Valvoline ATF-4+ because it's a readily available, cheaper alternative to buying Mopar ATF-4+ from the dealer. When it comes to transmission fluid, quantity is better than quality. Don't buy a high priced transmission fluid because ideally you don't want to run it the length of time it would take for it to pay off. I use the Valvoline because I dump the fluid that's in the pan about every 20k (I credit "Texas CTD" for that method), change the filter each time, or maybe every other, and replace the fluid. At that rate, the fluid always stays fresh and clean, and you never have to worry about needing a full flush.
Check what Napa wants for the filter first before you buy it. Genos has Mopar filters for $18, and $29 if you want an extra gasket as well.
I also use Valvoline ATF+4® in each of the trucks listed in my signature. The 2001.5 has 164,000 on the original 47RE transmission,which remains strong and trouble free. I change the fluid at or around the 20k interval to keep the additive pack in the fluid fresh.
I have attached a link which may be helpful with making a decision.
http://www.centerforqa.com/licensedatf4brands.html
Is it recomended to try and pump the rest of the tranny fluid out after draining pan by running truck breifly in neutral? (To get ALL 17 quarts of the fluid out)
I agree also, WalMart is best place to get the MOPAR ATF+4
I changed my fluid about 5k ago and used Pennzoil ATF+4 from NAPA. It was a $1 cheaper than Walmart and has been working fine. I also got the filter from them, but I can't remember what the price was. The gaskets that come with the filter are not even close to the quality of the stock piece. Pick up a drain plug to put in the pan for future changes.
It should be noted that the Mopar ATF-4+ is only sold at select Walmarts. I haven't even been unable to find it at any Walmart in the tri-county area. The Valvoline I found at Autozone.
