Whats the best filter for stock canister?
im going to start running my fass 95/150 through the stock canister housing and another single filter pad later on. whats the best um rating for the stock filter. i would like part numbers for wix,baldwin fleetguard lubefiner etc...
thanks |
The best one I've seen is the 5 Micron Baldwin PF7977. I believe the Mopar and Fleetguard are 7 Micron.
Baldwin is the best you will find for a stock canister.
You will find that information in the spreadsheet located in the attached thread. Member AH64ID has clearly done an extensive amount of research on fuel filtration and his outstandiing efforts are greatly appreciated. The link is attached for your review.
https://www.dieseltruckresource.com/...a-t273129.html |
whats the gpm rating of those filters? will they restrict the fass 150 gph?
