-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   What should you use to clean battery cables? (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/what-should-you-use-clean-battery-cables-298146/)
Roperteacher Dec 7, 2011 11:40 AM
I noticed my battery cables on one side are starting to build up? WIre brush and then spray on that red cable conditioning stuff? Thanks!
riddle family Dec 7, 2011 12:29 PM
Use a little baking soda with water, then use the wirebrush...
jballou Dec 7, 2011 02:12 PM
Alternately, coke can be used. Yes the soda. Once the cable is cleaned and replaced, a clear spray paint to seal out the air.
Roperteacher Dec 7, 2011 04:16 PM
I bought some of that red spray to coat the terminals. Will take care of it soon! Thanks!
ubet Dec 7, 2011 08:01 PM
2nd on coke (the drink, not the powder)
wiskeyVI Dec 8, 2011 05:55 PM
I'm cleaning mine this weekend. I'll have to try the paint idea...These corrode more than any others I'v had.
iweb Dec 8, 2011 06:51 PM
Be careful with the coke, I dropped a can by my truck and it sprung a leak and sprayed coke on the front fender. I cleaned it off right away with a hose but didn't get it all and now I have 3 spots the size of an eraser down to bare metal.
.boB Dec 11, 2011 11:24 AM
Oddly enough, I have noticed this truck developes batery corrosion quicker than any vehicle I'v ever owned.
I use the felt pads and the spray, and I still need to clean it every year or so.
torquefan Dec 11, 2011 12:15 PM
That's often a result of a battery that isn't sealed properly around the posts. It might be time for replacements before you have to replace cables too.
PWong Dec 11, 2011 05:08 PM
Pour HOT water on battery terminals. Nice and clean.
Do it three to four times a year.
Nate-03 D Dec 11, 2011 08:15 PM
I like to cover my terminals in grease, like a chassis grease used for ball joints or u-joints. I've been using it on semi tractors for years with great results.
Rednax Dec 12, 2011 11:06 PM
The cabling itself, or the terminals?
For the cables use any mechanis handcleaner.
For the terminals, after cleaning them use NO-ALOX (Home Depot, etc). You'll never have corrosion again. Just re-do every 4-years or so. Use batt clean brush/tool to get mating surfaces correct, use N-A, install, and wipe off excess.
Be sure to knead package contents thoroughly. Also can use in incandescent fixture bases. Don't slop around. It improves conductivity.
Rednax Dec 12, 2011 11:07 PM
http://image.made-in-china.com/2f0j0...ated-Yc214.jpg
http://images.lowes.com/product/conv...50300266lg.jpg
ssandlin Dec 13, 2011 12:32 PM
x2 on this once you have the terminals cleaned.
