What replacment aif filter should I use?
Old Oct 11, 2006 | 04:55 PM
PapaPerk's Avatar
I need to replace my air filter. What do you guys recommend? Last one I did came from the dealer. Is there a better drop in filter out there? I would like to get a cold air intake one day... but for now I think a drop in is the way to go.
Thanks
Old Oct 11, 2006 | 05:25 PM
anni2VADER's Avatar
PAPA, i use the airraid dropin. it has the extra layer of fiber protection that the k&n doesnt.
Old Oct 11, 2006 | 11:03 PM
redstreak's Avatar
AFE drop in works really well too.
Old Oct 11, 2006 | 11:08 PM
2500's Avatar
been using K & N for years, so that's what I went with...
Old Oct 12, 2006 | 01:30 AM
bcfirefighter's Avatar
stage ii afe is the way i went and i love it....easy install as well
Old Oct 12, 2006 | 08:36 AM
mule3010's Avatar
I use the Airaid drop in and have no dust in the tube what so ever. With the Fleetguard my filter minder would get pulled down in the 1st few K. With the Airaid I can go much, much longer without any movement of the filter minder.
Joe
Old Oct 12, 2006 | 10:32 AM
heredia_mike's Avatar
Another i recommend is trueflow. I’ve had the product for a few months and I am pleased with it. You can check them out at trueflow.com
Old Oct 12, 2006 | 10:44 AM
bigredBCS's Avatar
ive got a K&N filter, and it works really good!i like how it uses the whole box instead of just sitting on top like the K&N did in my 2nd gen
http://www.kandn.com/images/l/E-0776.jpg
Old Oct 12, 2006 | 08:16 PM
alMout's Avatar
The regular Wix, or Napa Gold, replacement filter has a much higher flow rate than the Mopar. That is what I use.
Old Oct 12, 2006 | 08:52 PM
surfram's Avatar
Napa Gold
Old Oct 12, 2006 | 09:08 PM
03 ant a hemi's Avatar
Air filters. Be very carefull what filters you use out there.
Here in the great white north. AKA Canada there has been a problem with air filters collasping in on themselves due to clogging with snow and or dirt. This has been attributed to, weak wire mesh in the filter front.
Cummins has redesigned the their stock air filter to accomadate this problem and added a more stiff steel mesh.
Although you can find or use other filters on this truck, be aware of the strength of the filter assy and use caution if driving in dusty, muddy, snowy conditions.
This is an internal DC notice for certain areas, Cummins has also done an internal note to their customers AKA dealers.
I have expieranced this myself with snow ingestion, and have seen and heard of guys trucks ranging from 03 to the new 07's with the same problems.
The stock air filter is more then enough for your engine, stay with the it.
Old Oct 13, 2006 | 08:46 AM
2broke2smoke's Avatar
interesting ... could you post the flow rates please?
Old Oct 13, 2006 | 12:35 PM
surfram's Avatar
Napa Gold 2846
Part Number: 42846
UPC Number: 765809428461
Principal Application: Dodge Ram P/U w/ 5.9L Turbo Diesel (03-06)
All Applications
Style: Air Filter Panel
Service: Air
Media: Paper
Length: 10.750
Width: 10.000
Height: 1.990
CFM: 675
Old Oct 13, 2006 | 05:50 PM
PapaPerk's Avatar
Originally Posted by surfram
Napa Gold 2846
CFM: 675
What does the K and N flow?
Old Oct 16, 2006 | 05:09 PM
alMout's Avatar
Wix - 675 CFM from Wix website. I do not know at what differential pressure this rating was taken at.
Mopar - 452 CFM at 4.66 in. Hg. per this web site.
