what differential and transmission fluid?
i was wanting to change my diffs and transmission fluid on the 03 in my sig with the nv5600. my question is what should i use, i was wanting to use amsoil. I tow a little bit. And also how much does each diff and the tranny hold? thanks
Off the top of my head, I recall 3 quarts in the front diff... 4 in the rear.
I don't know about the tranny. Amsoil is an excellent choice for both. Schaeffers is another for the diffs. The regular Mopar ATF +4 is good as well for the tranny. |
For the tranny use Amsoil MTF. Dump in 6 qts.
For the rear you can use 75w-90, 75w-110 or 75w-140. Front 75w-90. MikeyB |
Originally Posted by soulezoo
(Post 2334889)
I don't know about the tranny. Amsoil is an excellent choice for both. Schaeffers is another for the diffs. The regular Mopar ATF +4 is good as well for the tranny. MANUAL TRANSMISSION NOTE: DaimlerChrysler recommends using MoparT lubricants or lubricants of equal quality. NV5600 - MoparT Manual Transmission Lubricant NV4500 - MoparT Synthetic 75W-85 Manual Transmission Lubricant Getrag 238 - MoparT ATF+4 Transmission Fluid G 56 - MoparT ATF+4 Transmission Fluid T-56 - MoparT Synthetic 75W-85 Manual Transmission Lubricant NV5600 4.50 L (9.5 pts.) |
