What did my truck come with?
Old Jul 20, 2009 | 11:04 PM
fatpete's Avatar
Greetings Gents!
I'm trying to gather info on my truck...
Is there a way to contact Dodge and find out exactly what stuff it came with from the factory?
What gear ratio do I have? Here are the stats: 1650rpm@60mph, 1800rpm@65, 1950@70, 2100@75. That's with cabover as pictured. The window sticker (all I got from previous owner) says 11.50 rear axle. There's no mention of gear ratio under the hood, glovebox, door sticker, etc
What model transmission do I have? It's auto, the window sticker I got from the previous owner says 4-speed.
How do I know if I have leaky injectors?
Thanks for any insight,
fatpete
Old Jul 20, 2009 | 11:15 PM
Totallyrad's Avatar
Leaky injectors are easy, look for your engine oil level to go up. When they leak it goes into the crank case and your oil level increases. I believe any dealer can run your VIN and tell you about your trucks build specs.
Old Jul 21, 2009 | 11:07 AM
FunFinder5's Avatar
Originally Posted by fatpete
...What gear ratio do I have? Here are the stats: 1650rpm@60mph, 1800rpm@65, 1950@70, 2100@75...
You have a 48RE auto transmission w/ 3.73 rear end ratio
Old Jul 21, 2009 | 12:28 PM
ssandlin's Avatar
I'll second that as FatPete and I have the same truck and those RPMs match mine at those speeds.
Old Jul 22, 2009 | 01:59 PM
fatpete's Avatar
Thanks guys. That's what I was looking for!
supr
Jan 5, 2010 09:11 AM
redsealdodge
31
Dec 7, 2007 05:22 PM
