What is this?
Old Apr 3, 2004 | 06:40 PM
dcorneli's Avatar
What is this?
Crawling around under my still pristine 2500 this afternoon, I saw this up on the driver's side. It seems to have transmission lines going to it. Is it some type of cooler?
Thanks,
David
Old Apr 3, 2004 | 06:41 PM
dcorneli's Avatar
Another Shot
Wider angle.
Old Apr 3, 2004 | 06:55 PM
2003Ram's Avatar
that looks like the tranny cooler they had to replace on My '03 for the C-44 recall.
Old Apr 3, 2004 | 09:33 PM
Tom488's Avatar
That's the water-to-oil transmission heat exchanger, standard on all diesel trucks. Hot tranny fluid flows through this first, then on to the air-to-oil cooler in front of the radiator, then back to the transmission.
It's also the fluid resevoir that's just waiting to dump about a half-gallon of ATF all over you when you go to change out your tranny line for one with a temperature port. Not that I have any direct evidence of this, or anything...
Old Apr 4, 2004 | 12:14 PM
dcorneli's Avatar
Thanks! I knew it was something I hadn't seen on my gassers. I'm new to diesels and I'm trying to learn more by rolling around underneath!
David
Old Apr 5, 2004 | 12:00 PM
bigblock2stroke's Avatar
Only the autos have that cooler.
