Water pump R & R, 2004.5 with shortcuts
#61
Thanks for the great write up!! Just installed pump #3 at 188K on the '06 Mega Cab 2WD. Pump #2 was a Napa lifetime warranty. My excellent other half had the receipt from 3yrs ago, so the pump was free. 4gallons of
Zerex G5, new upper and lower hoses, and good to go.
The radiator shroud tip is great. I have done it before by taking out the air box, but this is better. The tip for filling to the removed heater hose is right on the money!!
Now for a tip I hope can help some of you. When I did the first replacement, I had trouble getting the pump to seal to the block. I ordered a couple of O rings from McMaster Carr that are a little wider than the square sealing ring:
Viton(R) Fluoroelastomer O-Ring, AS568A Dash Number 415
A LITTLE good RTV in the pump groove and no more leaks!! Hope this helps some of you that have helped me in my 6+ years of lurking...
Thanks again!!
Thanks again!!
#63
Sparkybob: Did you use two of the new O rings or was one enough?
I also went with the lifetime water pump warranty. Next time I will change it when it starts leaking instead of pushing it another 15K miles.
#65
Had to do mine today at 77449 miles. Went just fine per the instructions at the start of this thread. I did remove my air box and that helped a lot with moving around the pump area.
47
47
#67
Sorry to ask this possibly stupid question...
Do I pull the hose on the head before I start draining the radiator or after the radiator fully drains?
Does the therostat have to be pulled in order to fully drain?
Does it matter?
Thank you for the write up. I'm attempting this on my own tonight.
Also, any tips on how to get the belt back on by myself?
Does it matter?
#73
If I can do it following Ricks instructions, anybody can do it.
#75
Totallyrad, thanks for this write up. Remembered reading this a while ago and found it again. Printed it up and went to help a friend broke down on the road..
My friend needed to change out his pump on his truck and we followed it to the letter without a hitch. I would like to mention we did add another item.
On the hose coming from the head to the interior heater core, we installed a T, barbs on each end and a bull plug in the center. Weight was minimal, but when refilling we installed a barb and a piece of hose and refilled.
It gave a high point that was well above the radiator cap and seemed to totally fill the system. When filled, we removed the temp barb and hose and installed the bull plug.
Might consider adding this, or not if you want. But the write up saved us one heck of a lot of time. It was on the highway in a rest stop, which hindered a bit with the rains coming and going. Save my friend a ton of money, including towing and the dealers cost.
Thanks again.
Thanks again.
