Wait to start light
Old Jun 28, 2010 | 06:58 PM
kim98642's Avatar
Question Wait to start light
I just purchased a low miles 2006 5.9L Ram 2500. The wait to start light does not come on when I turn the key to ON. Do all dodge diesels have a glow plug or is there something wrong with my light or glow plug system.
Old Jun 28, 2010 | 08:05 PM
Spooler's Avatar
We don't have glow plugs. We have a grid heater under the intake horn. No, it will not come on unless under a certain temp (45 deg F). Truck will start fine without it.
Old Jun 28, 2010 | 08:49 PM
Ram Guy's Avatar
My wait to start comes on EVERY time I start the truck. If it is hot out and the truck is hot then it still comes on if even for only 3 seconds. But it ALWAYS comes on...Not saying the grid heater is necessarily coming on though.
Old Jun 28, 2010 | 09:05 PM
astep577's Avatar
my dad has an 06 and the past two whole years, i have never seen a wait to start light come on. i just bought an 03 so and its wait to start comes on for at least three seconds even in this 90 weather. maybe they changed something around over those couple years...
Old Jun 28, 2010 | 09:15 PM
RDM16CTD's Avatar
The Wait To Start light on my truck always comes on as part of the check where all the dash lights are coming on and going off when the key is turned to On. If it's below 65 degrees F (engine temp where the sensor is - not necessarily the outside temp) then the WTS light will remain on for a period of time - there's an audible 'click' when the grid heaters turn off and the WTS light goes out
Old Jun 28, 2010 | 09:35 PM
Brookster's Avatar
X2 Mine is the same, comes on just as the other lights a few then goes out. IF the weather is nice turn the key and go............................
Old Jun 28, 2010 | 09:45 PM
ripping r's Avatar
x3 mine is the same.
Old Jun 29, 2010 | 12:27 AM
madhat's Avatar
Administrator/Jarhead
At a certain year, the WTS light does not come on with the bulb check, it only comes on when it is cold enough.
Old Jun 29, 2010 | 10:48 AM
HOD-ISB's Avatar
Madhat, I believe it began in 06 that the WTS light no longer comes on as a bulb check. Funny thing is that the manual for the 06s wasn't updated fast enough and it still says the bulb does a check but that is untrue.
Old Jun 29, 2010 | 01:29 PM
kim98642's Avatar
Thanks all so much, That clears it up for me.
Old Jun 29, 2010 | 05:29 PM
steelblitzkrieg's Avatar
DTR Detective
My 2006 comes on during the initial dash check. Mine was an early 06 (November 2005), maybe they changed after mine? As to WTS, I only wait if it's in the 20's and even then I don't think you need to according to what I recall from the manual.
Old Jun 29, 2010 | 07:34 PM
banana's Avatar
Mine (light) only comes on when its cold outside, but you can watch the Voltage meter drop, as long as the intake heater is on (no matter what temp....)
I think it stays on for a while, even with the engine running...
Old Jun 29, 2010 | 08:16 PM
hector's Avatar
Mine is an 07. The manual states the light /grid heater comes on when the sensor senses a temp 66 deg or below. Mine only comes on durning cold weather. Warm weather no light
Old Jun 30, 2010 | 10:57 AM
HOD-ISB's Avatar
That's interesting, and definitely explains why the manuals were inaccurate in this respect. I just assumed it was something that changed with the introduction of the can bus or a misprint...etc. Since there have been so many over the years My truck is an 06.5 (May 06)
Old Jul 1, 2010 | 03:52 PM
DBLR's Avatar
I have and early 2006 (9/2005 with a 8/2005 engine) and the WTS light for the grid heater does not come on unless the temp is under 66 degrees
