vibration and locked wheel
Last weekend I noticed a vibration. I couldn't tell where it was coming from and it seemed to happen at different speeds and RPM's. I lifted the rear tires off the ground and I couldn't spin the driver's side rear at all. The passenger spun freely. I took the tires off worked the emergency brake and it seems to be better but still have the vibration. Any thoughts?
Check your rear U-joint I had one sieze up on me caused a very bad vibration and rear wheel locking.
You should also check the brake caliper to make sure it is releaseing the rotor. Compare the tempature of the wheel hubs after driveing a mile or two. They should not be hot and should be the same temp.
Thanks for the help guys. Looks like it is the caliper, the wheel was locked up, as soon as I pulled the caliper and brakes off it spun freely. Also the breaks were shot. Looked like they got really hot...they were just falling apart. I guess I will be putting on new rear pads and changing a caliper, unless the caliper can be repaired?
Replace the caliper.
You need to determine why the caliper stuck. It could be the rubber line not letting the pressure return to the master cylinder. |
Originally Posted by dieselnut932
(Post 2967728)
If the rotor has the least bit of bluing, it's toast. Replace it. |
I changed the caliper and brakes. Do I have to fill the resevoir with fluid, or can I just pump the brake pedal to fill it up?
You have to bleed all the air out of the system by bleeding the brakes.
You need to completly fill the master cylinder. Get some one to help.
Start on the wheel that is closest to the master cylinder. Open the bleeder valve and place a container to catch the fluid as it is pumped out. Have the other person push the brake pedal to the floor and hold it there. Close the bleeder valve, then the other person can release the brake pedal. Repeat the above procedure 3 or 4 times. Refill the master cylinder. Do not let the master cylinder run out of fluid or you will pump air into the lines and cause problems. Repeat the process until the fluid comes out without any bubbles or air. Then go to the other wheel on that axle and repeat the process. I like to pump enough fluid out to get fresh fluid into the system at all 4 wheels. This can take 2 or 3 cans of fluid. Do not use any fluid that has been open for any length of time as it will absorb mosture. |
thanks papaduck, got everything bled out, and all is well.
