vibration at idle
vibration at idle
Does any one else have an abnormal vibration at idle ??? the dealer has had the truck for another week now ,admits there is a vibration. but cannot figure it out.
Re:vibration at idle
First off you didn't say if you have an Auto or Manual Tranny. This info can make a big difference. The auto tranny does have a problem with a slight vibration due to the dip stick being tie wrapped to the heater hose on the passenger side.
Maybe this will help. 8)
Tell them to make sure nothing is grounding out on the chassis. If it is a slushbox do you have the vibration in reverse and drive? If only one way you usually have a grounding problem. If both ways you might have a engine mounting problem or imbalance. Sometimes the motor mounts need to me neutralized. HTH
Has the dealer done an engine power balance? If you have a miss at idle the truck will shake. Mine is a 6spd but quite smooth at idle. Not BMW smooth but I think it is good for an inline 6 oil burner.
[quote author=deje link=board=20;threadid=18443;start=0#msg173094 date=1060993183]
[/quote]
ok i do not have anything at idle but when i am coming to a stop slowly it seems the whole dash near the window seems to vibrate... then when i accelerate slowly from a stop i hear it again...do you guys know what this vibe is? :'(
[/quote]
dodgedsl03
Jan 18, 2007 10:08 PM
TurnerBurn
Mar 6, 2006 08:51 PM
Jdub
14
Sep 25, 2003 04:44 PM
