??Vibration??
Old Mar 6, 2008 | 09:39 AM
Tin man's Avatar
??Vibration??
HELP, I am new to the Cummins world and dont know anything about them. In 5th and 6th gear 50 mph and up but only under a pull it has a vibration, just rolling it dont do it. Its a 2005 3500 dually 6 speed with 99,000 on it. Just got it three weeks ago. So what do yall think it could be. THANKS
Old Mar 6, 2008 | 09:55 AM
vzdude's Avatar
DTR's 'Go to Guy'
Sure sounds like a u-joint.
Old Mar 6, 2008 | 07:50 PM
dozer12216's Avatar
A u-joint is certainlly a possibility. Is it fast enough to beat your ears to death or is more of steering wheel vib or perhaps the hood or rear view mirror shake.
Beat your ears = u-joints or drive line.
Steering wheel, hood, rear view mirrow, seat, or belly shake = tire/wheel issues.
Old Mar 6, 2008 | 09:14 PM
Tin man's Avatar
you can feel it through the Steering wheel and the shifter but only when it is in a pull.
Old Mar 7, 2008 | 07:06 AM
ColdCase's Avatar
Does it vary more with engine RPM than road speed? Most likely a U joint, but you could also have a weak cylinder. Try a search on the word joint and see if anything comes up that matches your symptoms.
Old Mar 7, 2008 | 08:22 AM
Tin man's Avatar
It runs great and pulls grea,t just in 5th & 6th gear and higher than 45mph.
Old Mar 7, 2008 | 08:35 AM
frank compagnon's Avatar
steady bearing and or u-joints. had a similar feeling in my 03 and replaced the bearing and when i got the drive shaft out, two joints were bad. after that was done the truck had on viberation
dodgedsl03
Jan 18, 2007 10:08 PM
Davidp
Mar 19, 2003 11:29 PM
spitzair
Mar 11, 2003 11:06 PM
deere nut
Dec 1, 2002 08:09 AM
chdiesel
Nov 3, 2002 04:39 PM
