u-joints?
Old Mar 26, 2007 | 05:37 PM
NGM Diesel 1's Avatar
u-joints?
anyone know what size or part# we have on our trucks for the front axel, front drive shaft and the rear drive shaft? i have to replace all mine and would like to get some info on them. it would be a spicer/dana # thanks
Old Mar 26, 2007 | 05:38 PM
rjm022's Avatar
i had mine done last year- don't have my part numbers- but get the spicer greasable ones!
Old Mar 26, 2007 | 07:24 PM
where did you get them?
Old Mar 26, 2007 | 08:03 PM
rjm022's Avatar
i bought mine from a shop that only does drive shafts. i dropped my shaft and brought it to them and they installed the u-joints.
Old Mar 26, 2007 | 08:24 PM
boarbuster's Avatar
Rear driveshaft 2 Piece precision (takes 3) Precision #351
Front driveshaft Cardan H joint (takes 2) Precision #232
Front driveshaft @ front axle (takes 1) Precision #235
Front Axle U joints LEFT AND RIGHT (takes 2) #464
All the U Joints listed above are PRECISION brand and are GREASABLE!!
Precision can be had at your local NAPA auto parts or online at napaautoparts.com or rockauto.com (ROCK AUTO IS WAY CHEAPER!)
I think these are right. When i did all my u-joints on my 04 i opted for the nongreasable ones(personal preference). You can decide which ones that fit your needs.
Old Mar 27, 2007 | 03:11 AM
thanks a lot
Old Mar 27, 2007 | 06:02 AM
PourinDiesel's Avatar
Originally Posted by NGM Diesel 1
thanks a lot
Wait a minute there the only ones that apply to your truck are the axle knuckle joints #464 which work on all 4x4 3rd gens.
The rest of those joints in that post are for a manual trans truck (I know that because I wrote that list).
Wade,
Check www.rockauto.com they should have a full list of joints that fit your truck. Just take your time in sifting through all the different joints.
On second thought....
As far as the front driveshaft goes go to mopar4less.com and just order a whole new front shaft assembly for your truck. It will actually be cheaper than rebuilding the existing unit. I just bought my new front shaft from them for $196 that included both yokes, greasable cardan, 3 u joints, and the 2 piece shaft all assembled and ready to bolt in. Can't beat that deal with a stick.
The rear driveshaft assemlby new will run you about $400 or less if you have a short wheel base (by about 100) direct from dodge ready to bolt in.
It will probably be cheaper just to buy new u joints for the rear. As I remember I think the auto's took a #330A Precision (rock auto)u joint for the rear shaft they take two for swb or 3 for a lwb.
Old Mar 27, 2007 | 07:35 AM
Crabjoe's Avatar
Wade,
Thanks for the correction... I was at Rockauto yesterday morning and couldn't make out what part was for which....
It seems odd to me that Dodge would use different U-joints depending on a auto vs manual.
Old Mar 27, 2007 | 04:38 PM
thanks guys
i spent $162 for the (2) fronts (2 rear) and one front shaft 2nd day aired. all greasable! now i need to find the t-case side front shaft, rock auto did not have a listing for them?
kprc51
Jun 14, 2007 06:27 AM
njmaier
15
Jul 26, 2006 07:43 AM
getblown5.9
May 2, 2006 10:01 PM
Seeder
Feb 15, 2006 08:15 PM
Dynocon
Mar 5, 2005 06:24 PM
