-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   U joint & Ball joint with Dynatrac (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/u-joint-ball-joint-dynatrac-149961/)
Treangen May 7, 2007 10:56 AM
I am going oot be putting my dynatrac kit on shortly. Should I just replace the front u joints and ball joints right away since it will be tore down?? 2006 with 35K on the ticker with no noticeable problems in the u or ball joint arena. If so, part numbers anyone??
DiEseLjunKy May 7, 2007 12:08 PM
Might not be a bad idea since you've got it all apart anyways and make sure the replacement ujoints you get have a grease fitting. Sorry don't know the part#s but I've seen them posted in different threads before or someone may chime in on that. And post pics of the finished install when you git r done. I'm doing the same mod in a few weeks and already got the kit here waiting
Boz007 May 7, 2007 01:50 PM
Im so jealous. I want this kit.
I agree with junKy, you might as well put new stuff in since you'll have it all torn down.
Pooter May 7, 2007 02:52 PM
I would. Id replace them with greasable units. If you already have the truck apart, its worth not having the headache on down the line...(well, itll give you more time, and a serviceable Ujoint/ball joint)
Treangen May 7, 2007 03:10 PM
So part numbers for a 2006 3500 megacab with CTD????
