Truck slips at take off. Manual transmission
Old May 16, 2009 | 11:38 AM
pooperscooper's Avatar
Stock clutch and DM flywheel. 65k
g56- 20k since last oil change.
3/4 ton 4x4. 37' tires
I replaced my rear lower rear driveshaft u joint last week. Later on that week, i noticed as I take off from a stop my truck almost slips and then catches up. It is extremely difficult to describe. But it feels like an auto tranny slipping just ever so slightly, and then bangs into gear. Of course i get not mechanical sounds or actual slamming of parts.
Take off is preformed in 1st, or second, same results. It seems to be about 3/4 clutch engagement. (seems to be worse when warm, but hard to tell)
Now, when I was on a very steep incline paved road, I slowly let my truck crawl up the hill. As soon as I gave it some skinny pedal, it did the slight slip.
I can tell it is doing something different. What I can’t figure out is what the problem is. The law of reason tells me it is that u-joint. or is it? I have pulled the driveshaft; check both the U-joints. Seems fine, both move freely. Could a u joint really cause this problem, or is it a coincidence. I have my own suspicions but I would like to see what some other people think.
I have checked the rear end for particles, nothing more than a fine coat of metal. (looks like antiseize) not sure how much is normal, but there was no actually pieces, more like wear than damage. (30k miles) on diff oil change. Nothing seems wierd inside the transmission as far as shifting. clutch slips with smarty turned up. running on 5 and notice no slipping.
Thanks in advance. I welcome any and all comments or suggestions.
Old May 16, 2009 | 12:18 PM
rich's Avatar
the dm flywheel on some of these trucks have come apart from what the dealer has told me any new vibrations. clutch could also be getting worn out tho too
Old May 17, 2009 | 09:02 PM
Jeff in TD's Avatar
U joints I wouldn't think would slip, nor would the ring and pinion.
I'd also bet your DMF and clutch is not long for this world.
I see in your signature you are awaiting a southbend double disk, and I suspect when you get that in your slipping will be gone.
Old May 17, 2009 | 10:48 PM
txarrowhunter's Avatar
I lost intrest after the second sentence, but my brothers truck was doing the same thing and just replaced clutch and flywheel $1750 sliping stopped
Old May 18, 2009 | 08:54 AM
OOPS's Avatar
Clutch is going south, did you change the R&P gears when you put the 37" tires on. Big tires change gear ratios.
driftingfly
Oct 5, 2013 08:16 PM
Deer716
Feb 16, 2010 06:58 PM
cLAYH
Jul 17, 2008 10:41 AM
jhpate
17
May 30, 2008 07:08 PM
Bigdaddystroker
Aug 8, 2007 01:02 AM
