transmission problem
Old Feb 11, 2010 | 11:44 PM
skwelder's Avatar
I have an 03 with an auto transmission. The problem is it starts out in second gear when in drive. The only way i can get it to start out in first is to shift it into first, then shift to second manually, but then it won't shift back to first if i shift it back. I have to come to a dead stop put the truck in first then it will start in first again. When idling at a stop light in drive you can feel the truck give a slight quick jerk once in awhile as it shifts in to first but then shifts back into second. Another thing it does is when shifting from 3 to o/d under light throttle the trans gets confused, the rpm's jump up and down, it's like it doesn't know if it should shift or not. It only does the under light throttle, under harder acceleration it shifts fine from 3rd to o/d. trans fluid looks good, doesn't smell burnt and is at proper level.
Old Aug 12, 2010 | 11:48 PM
Crazyhorse's Avatar
I have the exact same problem with my 01, I was really hoping somebody had some answers. the guys here are pretty good at pinpointing a fix.
Dauntless
15
Aug 30, 2016 08:37 PM
TGCTD
Jun 25, 2004 09:47 PM
dogman
Dec 27, 2003 07:06 PM
jec3
Jun 9, 2003 01:35 PM
NWDave
Nov 24, 2002 09:25 PM
