Transfer case linkage gone?
I heard a loud clunk under the truck and then my transfer case sfiter vibrated and went slack.
I looked under the truck and the linkage arm is gone, must of come loose on one side and hit the drive shaft. Both linkage ends look fine (on the shifter and on the transfer case), just no linkage arm/adjustable rod. Has this ever happened to anyone else? I guess the dealer is the only one for parts? Thx! |
Before you try the dealer do a google search and you might find a place, might save you some money
Call dealer and arm is $27 and the bushings for the ends are $7 each. Not to bad of a price.
Funy thing is, that the bolt that adjusts the tension/length does not come with it and is not offered. :confused: I am sure I can find a bolt at Lowes. |
