-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Trans Temp light (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/trans-temp-light-39912/)
gdh11 Feb 27, 2004 05:28 AM
Trans Temp light
Yesterday in the snow storm I was in 4x4 and my tranny light kept coming on and flashing as I came down to idle. My guage didn't register over 100 degrees. It was butt cold and I was not hauling anything at the time. Anyone have any ideas?
handymantim Feb 27, 2004 07:13 AM
Fluid level OK?
SBishop Feb 27, 2004 03:15 PM
You are about the third person who has had dash light hiccups while in the snow. I suspect that some connection under the hood or at the tranny is not water tight and getting wet.
handymantim Feb 27, 2004 03:56 PM
That's a good idea. My shop manual says that the light is activated when the temp sensor goes to ground......which could be caused by water in the connector(s).
gdh11 Feb 28, 2004 02:32 AM
I got under there yesterday and the entire tranny was surrounded by snow. I took it out yesterday after removing most of the snow and had no light. After I get the wires good and dry I will get some of that spray rubber that insulates wires and hit the connectors under there. I am sure it was nothing but some connector that was wet and cross firing with another wire at a connection. The tranny temp guage I have was barely over 100 degrees. Sad job of insulating witres from the factory.
SuperGewl Feb 28, 2004 01:56 PM
You may want to check for a recall. I know that mine had a recall for the tranny to tranny cooler line that could possibly fex too much and cause the inlet connection to the tranny cooler to break and cause a tranny fluid leak which would inturn cause a tranny overtemp light:confused:
You may want to look into it and see if it al pplies to your truck.
go to this link:
http://www.dodge.com/webselfservice/...m%28%27R%27%29
put in the info they need and see what pops up[whistle]
