trans not shifting well
03 2500 diesel -had complete trans flush about 1500 miles ago pulled 5er on vacation everything ok ,now it is having trouble shifting out of 1st. after running then stopping and starting up again! its fine when it sits for a period of time I just passed 70,000 miles on it (out of warranty) going to call dealer who did flush and see what they say, any thoughts ,thanks for any help you can give
Not sure if it helps or pertains to your situation, but the transmissions do "adjust" themselves to your driving. Maybe the trip with the 5er was long enough for the trans learn to hold gears longer to get power up?
You need to set the E-brake and check it with the truck in Neutral so that fluid is running through the tranny cooler. Do that and see how it looks on the stick.
If it's overfull when hot then take some out. They seem to change levels on their own. Mine has been low after the 60k band adjustment at the dealer. It shifted just fine until the temps got real warm last week, Ihad to add about 1/2 quart.
thanks I checked it in park (getting old and not thinking ) I'll see whats on the stick
thanks I checked it in park ( getting old and not thinking ) will check again the right way! by the way, it has been shifting smooth the last two days no problem.
I had mine serviced at the dealer and when I got home I checked the fluid in Netrual and it was down 1.5 Quarts. Dealer said the Mechanic normally works on jeeps and they are checked in Park. Makes me wonder what he did inside the Trans?????
Jeeps are to be checked in Neutral as well. That makes 2 stupid people at this dealership!
Oilguy
I recently read a post on another forum by a master transmission builder that said to NEVER do a flush, only do a drain, filter change, and fill.
http://dieselram.com/ubb/ultimatebb....=000016#000013
Look for posts by Tim Holt - something about a flush, if done by an hourly guy just following directions (as opposed to a master tech who's been around the block a few times) can cause problems by picking up bits of trash and forces it through the valve body and other highly sensitive places.
Whatever, it makes sense to me and I'll never have a 'flush' done by a McTranny shop - I'll just drain the Mag-Hytec and fill 'er up with +4 or +3 / LubeGuard.
I'm not sure how anyone could do a tranny flush wrong. New fluid is pumped into the pan and old fluid is removed after it is pumped out of the tranny. When new fluid is pumped into the pan it goes through the tranny filter before in enters any of the "sensitive" parts.
I do my own flushes by removing the line that goes back into the tranny after the cooler and running a clear poly tube to a bucket by the driver's door. Then I run the truck in neutral until nothing more comes out and then shut off truck (actually I put the back axle on jackstands and run the truck though different gears but neutral will work if you don't have jackstands). Refill the pan (Mag Hytec) and do over until all old fluid is pumped out.
tranny shifts
not to hijack your post , but Ive noticed twice now that sometimes my tranny will go to a full 2000-2400 rev before shifts. 98% of the time it goes thru the gears quickly and stays under 2000. I just bought the truck two days ago, should I disconnect the battery and "reset" the computer ?? 03 2500 diesel thanks in advance
