Tranny Issue
If I keep a steady throttle going about 45 at 1600rpm in 3rd gear every once in while it will flare up for a half second or so like it is slipping. It will only flare up a couple hundred rpm's, then go back to how it was running before. I had the gov pressure solenoid changed twice and this did not help and also did not get rid of my 1-2 shift hunt. Does anybody have any ideas what is wrong.
Stock tranny?
Yes totally stock tranny.
Gov. pressure sensor?
Just for the heck of it, overfill with a pint of ARF. I fought this one for quite a while. Seems was picking up air and losing pressure.
Also check brake switch. It will cause unlocking of torque converter without warning. There is a bulletin on upgraded gov pres solenoid or transducer for reducing low speed 1 - 2 hunting. Didn't fix mine though. Gave up and drive through the issue. Make sure throttle pressure cable is properlly adjusted. Sometimes just .010 off will mess things up on shifting. |
Originally Posted by cawt0123
(Post 2085219)
Since you already have the 1-2 hunt problem, a shift enhancer would be a good start on a cure. FYI, consider a shift kit also. Those tires and stock trans pressures are really hard on the direct clutches. |
