Tranny experts help please
I blew my tranny awhile back will thought I did ending up being a bad pressure sensor but got a rebuild anyway before I realized it was just a sensor. I put the suncoast extreme rebuild kit, ats flex plate, ats 5 star convertor, transgo shift kit and a derale cooler mounted under the bed. What is the normal operating temp of a 48re I've been told by the dealer its around 190-200 degrees seems kinda high to me and others on the forums so they are seeing nothing over 160-170 with the same derale cooler so where is it supposed to run? I can't even drive mine very much in the city cause it get hot around the 200-210 mark and it doesn't stop climbing then its starts acting funny and I have to let it cool off. What could be some causes of it getting that hot? Any help would be much appericated.
Sent from my HTC Sensation 4G using Tapatalk 2
170 - 200 degrees is certainly within norms. I have been a mechanic for almost 40 years and have seen temperatures very between 30 - 40 degrees depending on vehicle type and also guages. I would worry if temperatures were getting up around 230-240 but you might want to check your temperature using a different method than what you are using just too make sure you are getting the correct reading. I use autometer guages myself but I also have and infrared meter to make sure they are reading fairly accurately. My truck tends to run in the 170-190 range normally and when I pull an 18000 pound trailer it gets up to around 225 when pulling a hill but also cools down again when pulling on a flat surface. Just for a reference my truck pulling my trailer up a 7 degree hill for approximately 3 miles at 50 mph and 2000rpm will go from 190 - 225 and then it takes about 10 - 15 minutes to cool down again. I travel this hill atleast 3 - 4 times a week.
EverydayDiesel
24
Jul 19, 2008 09:31 PM
Wicked500R
14
Jan 22, 2008 04:27 PM
DodgeDemon
Jun 30, 2007 01:44 PM
SoTexRattler
Feb 13, 2007 03:37 PM
cumminsman02
Oct 11, 2004 05:09 PM
