Torque Converter and Jacobs Brake on the 2006
Old Jan 18, 2007 | 10:55 PM
danc46's Avatar
How is the Jacobs brake tied into the torque converter when installed on the 2006? Is operation of the Jake brake/torque converter controlled by the ECM or manual switch?
Thanks for all the help you guys have given me!
Old Jan 18, 2007 | 11:51 PM
iflych52's Avatar
Not quite sure of your question but the brake will only operate if the TC is locked up. there is a manual switch.
Old Jan 19, 2007 | 12:59 AM
Spooler's Avatar
It's all programed to work together via the ECM. Just turn the Jake brake on is all you have to do.
Old Jan 19, 2007 | 12:17 PM
DSLBURNER's Avatar
Install the Mopar exhaust brake. It works with the factory wiring, has better warranty, and the best part is, it will not affect the factory warranty.
NM
Old Jan 19, 2007 | 02:45 PM
Wobblin-Goblin's Avatar
DC has its own exhaust brake?
Old Jan 19, 2007 | 02:51 PM
Smokeman's Avatar
Made by Jacobs. Comes in a cummins box.
Old Jan 19, 2007 | 04:20 PM
LVTony's Avatar
The 06 ECM controls the TC and e-brake.
Here's the Cummins page with the part numbers cross reference at the bottom:
Cummins Ram Braking
Here's the Jacobs page with their part numbers at the bottom:
Jacobs Light Duty
The 06 ECM will work with the e-brake down to ~22 mph. The TC on the 06 48RE will lockup on 2nd, 3rd and OD.
Last edited by LVTony; Jan 19, 2007 at 04:42 PM. Reason: Got the URLs and URL link names backwards.
Old Jan 19, 2007 | 05:15 PM
danc46's Avatar
I know the Jacobs is the same as the Mopar and one hell of a lot cheaper from Cummins, both to purchase and have them install it. It would be covered under the Cummins engine warranty as well but only for 3 years or 36K miles.
LVTony - thanks for posting those links!
PS. Just called Southern Plains Cummins and they want $1079 plus 17% to order the Cummins/Mopar/Jacobs with $180+ shipping. It weighs less than 30 lbs! I won't be buying from either Cummins or the dealer!
Looks like it might be PacBrake for less than $700!
Old Jan 19, 2007 | 11:39 PM
LVTony's Avatar
You'll be happy with the Pacbrake. It works good.
If I had to choose again, I would probably go with Pacbrake just because it is compressed air operated; whereas, the Jake e-brake is vacuum operated. It would be nice to have a tank of compressed air to run other things...
lniemeyer2
Oct 24, 2012 12:11 PM
Shilohman
22
Nov 19, 2009 05:13 PM
mainer
Jul 17, 2007 07:13 PM
iflych52
25
Oct 10, 2006 09:25 PM
