tire psi
What tire psi are yall running with a 3500 drw, has good yar sr-a tires on it.
The tire says 80 psi max cold but when they were put on goodyear had 60 in them. |
i run 80 rears and 75 fronts
80 all around
work at a tire place we always put in less then is called for when installing them.
calls for 80psi put in 70 psi |
I have to run 65+ in front and 55- in rears. Bigger tires will screw with needed pressures.
What about with an srw? Does anyone run different pressures?
Originally Posted by dozer12216
(Post 2127339)
