thermostat housing leaking can i run it?
Old Mar 23, 2010 | 08:04 PM
1985cucv's Avatar
my thermostat housing is leaking a little bit i was wondering if i can run it until i get the new one. i will not be working the truck hard but it will get up to temp it loses about a quarter quart to half a quart then it stops leaking. so should i run it? thanks
Old Mar 23, 2010 | 08:20 PM
madhat's Avatar
Administrator/Jarhead
With a leaking t-stat housing, you may bring air into the system, causing the water pump to fail, increase pressure within the water jacket (causing lots of problems) and possibly blowing a freeze plug. Overheating could also be a problem.
These are worst case stuff, but I would run it as little as possible if you have to.
Old Mar 23, 2010 | 08:32 PM
1985cucv's Avatar
10 4 i wont run it thanks a lot mad hat
Old Mar 23, 2010 | 08:40 PM
madhat's Avatar
Like I said, that's probably the worst possible thing that could happen. If it's just a drip, you're probably ok for a little bit.
If you were bleeding, would you just keep walking around? (where's the 'shrugs shoulders smilie?)
Old Mar 23, 2010 | 09:22 PM
1985cucv's Avatar
does the motor bleed out the air on its own? thanks
Old Mar 23, 2010 | 10:29 PM
madhat's Avatar
If it is near the hole, and the fluid level is below that, then yes. If it is in the water jacket somewhere, then no. There are a lot of 'what if's ' in this. That, and I don't have the water path memorized off the top of my head.
When air pockets get trapped in the cooling system, it causes a lot of over heating problems...
j_martin
Jul 3, 2014 09:17 PM
Bookshelf
May 30, 2009 01:17 AM
stevesmitty
Mar 15, 2005 07:13 PM
Redleg
Mar 3, 2003 04:29 PM
