Swaping ECM's for mileage?
Old Dec 19, 2008 | 02:36 PM
cLAYH's Avatar
The engine ECMs are coded to the truck body ECMs. I swapped motors on my '03 and had to use the original engine ECM that came with the truck. When I first installed the replacment motor I used the ECM that came with it. Truck would start then die after 2 seconds and I got a security code. Had to swap in the ECM from the original engine that I pulled out to get it to run.
Buying a used ECM a swapping it in my require a trip to the dealer to get it flashed to accept your truck.
Old Dec 19, 2008 | 09:22 PM
Totallyrad's Avatar
Originally Posted by ratsun
I just picked it up and haven't had a chance to play with it but I thought the Smarty had a fuel saver program? Couldn't you just load that in and get what your looking for instead of changing out the ecm?
I have gotten 1.5 mpg better mileage with one of their programs. I was just looking for more. My best to date is 19.98 mpg. I've heard so many folks say they can get 2-3 mpg more with the early 04 vs the 04.5 so I was just wondering if anybody had given it a shot. I figured at $685 for a standard Smarty against the cost of a used ECM and a flash might be good $ents if it would net 2-3 mpg. We all know how to get the power out of this engine but I'm looking for economy..........first.
Old Dec 19, 2008 | 10:32 PM
CrashCade's Avatar
Originally Posted by haloman
The injectors are different, I am not sure how but they are different mechanically.
The injectors are physically different as well I believe. I don't think the 3rd injection event is responsible for a big mpg loss. I would bet if you messed around with enough different combinations of pressure, timing, and duration you could probably find a tune setup that would net you the 1-3 that you are looking for. I would say it is not worth the potential damage caused by swapping the ecms like that. What about the features that are available on 04.5 and up. There are actually quite a few creature comfort features and options that are in the electronics.
Just my .02
Old Dec 20, 2008 | 12:23 AM
JJPage's Avatar
Just my .02
The difference is 03/04 have 8 hole tips, 04.5+ have 5 hole tips, injector bodies are identical.
04.5+ have a narrower spray angle, allowing for more advance timing without spraying fuel outside the bowl of the piston. If the timing is so advanced, that it is "saturating" the crown of the piston, not only will it melt the piston(eventually), it will wash down the cylinder walls with un-burnt fuel, limiting lubrication. (unless you use 2-stoke oil).
This is one reason why programming for the 03/04 is critical(with stock injectors), you cannot run a program based on a 04.5+ max timing(TNT) on a 03/04 truck. You will spray fuel on the crown of your pistons and catastrophic failure will be the result.
03/04 owners, need to be aware of this. I have been a "lucky" offender, stacking with TST, EZ, etc.
Now start adding or subtracting injection events ? This is COOL!
Old Dec 20, 2008 | 09:59 AM
AH64ID's Avatar
Originally Posted by tool
Hmmm,
Interesting thread.
I tought I read somewhere that Marco tried this when they were programming the smarty and found that there were negative consequences to eliminating the third injection event.
But I could be wrong.
Yes, but that was taking the 3rd event away from a 04.5+ ECM.. The motor doesn't care, but the ECM didn't like it...
As far as the injector tips and angles, the ECM doesn't care.. Its based on the injector and bowl being matched, which they will stay if you swap ECM's.
I would think you could swap and 04.5 and 05, but not an 06 as the wiring is VERY different.. .
Lets get a couple of buddies that are bored, one with an 04 and one with an 05... Then swap and see.. .It should just be the ECM on the block, and a couple of plugs...
Old Dec 20, 2008 | 02:14 PM
cLAYH's Avatar
Buying a used ECM and swapping it in my require a trip to the dealer to get it flashed to accept your truck.
I think you missed the point of my post.....
Old Dec 23, 2008 | 01:09 PM
Bob Wagner's Avatar
You can NOT use a 03/04 ecm in a 04.5/05 truck. It will not work
Old Dec 23, 2008 | 07:42 PM
RDR's Avatar
RDR
Thanks for raining on my parade Bob!!
Hah.
theonlyz
25
May 15, 2009 06:34 PM
CReed
17
Feb 2, 2007 01:13 PM
gunracer1
Dec 18, 2006 08:18 AM
DODGE 92
Sep 4, 2006 07:27 PM
boughtadodge
Dec 6, 2002 01:11 PM
