-   3rd Gen Engine and Drivetrain -> 2003-2007 (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/)
-   -   Survey: 48RE (https://www.dieseltruckresource.com/forums/3rd-gen-engine-drivetrain-2003-2007-102/survey-48re-39062/)
diirk Feb 11, 2004 02:34 PM
Survey: 48RE
Because of all the concerns over the quality of the 48RE tranny, I'd like to compile some data on the subject. For those of you with a 48RE, please respond with the following information, and anything else you think may be pertinent.
Year:
Model:
Mileage:
Gearing:
Item Towed:
Problems:
Mods:
Other:
Thanks...
mymaur Feb 11, 2004 05:25 PM
Re: Survey: 48RE
Year:2003
Model: ext cab long bed
Mileage:8K
Gearing:3.73
Item Towed: nothing
Problems:Zero
Mods:Zero
Other: THis entire 48RE problem thing is exagerated. Some guy aon another forum said there is a possible problem with an oil slinger on the rear planetary gear and they will fail around 50K.
THey are warranted to 70K, if they start having massive failures, DC will recall them. This isssue needs to be put to rest.
Every manufacturer has problems. I personally wouldn't have a Ford Diesel and the Duramax is supposed to be good unless you tow, then the injectors are an issue. Fords auto trans are good their clutches on the manuals are not.
THe 48RE has not been out long enough to say it's no good. Personally I think it's a good unit.
Thanks...
bigtobe Feb 11, 2004 06:37 PM
Re: Survey: 48RE
Year:2003
Model: Quad Cab (standard bed)
Mileage: 19K
Gearing: 4.10
Item Towed: Trailer w/ 2 4-wheelers, and one in the truck
Problems: None
Mods: None
Other:
dodgedude361 Feb 11, 2004 06:46 PM
Re: Survey: 48RE
Year:2003
Model:qc swb
Mileage:19,000
Gearing:373
Item Towed: 6,000 tt
Problems:NONE
Mods:none
Other:its aaallll good
Thanks...
Lightman Feb 11, 2004 07:42 PM
Re: Survey: 48RE
Year: 2004
Model: 2500 HO
Mileage:10K
Gearing:.3.73
Item Towed: Nothing heavy, a few ATV's. Next week 6000lb TT.
Problems: Transfer Case Seals(2) leaking, occasional strange shifts and torque converter lockups.
Mods:none to tranny
Other: Feels pretty tight and solid other than some odd shifts here and there. Can't wait to see next week how it does with 6k lbs behind it.
Thanks...
03CTDCO Feb 11, 2004 07:57 PM
Year: 2003
Model: 2500 HO QC 48RE
Mileage:4700 miles so far
Gearing:.3.73
Item Towed: 31ft 5er...10Klbs loaded
Problems: Transfer Case Seals(2) leaking, (replaced) strange shifts and torque converter lockups sometimes.
Mods:ATS for tranny maybe
Other: Truck runs GREAT..Tranny is stout !!
My ONLY complaint was non approval of the Jacobs EB. My dealer
mislead me and said I could have one installed. Live and learn.
Living in Colorado, I really think a EB is needed for safely decending mountain passes. I will try the mountains without it
then make a decision. Prolly will do a ATS Triple Lock TC, VB, PacBrake, and ATS controller if I feel the brakes are over heating
after a couple dry runs. $4800 bucks for ATS mods.:o
Vittorio Feb 11, 2004 08:24 PM
Year: 2004
Model: SLT SB 4 x4
Mileage: 16K
Gearing: 3:73
Item Towed:Livestock, Horses and Hay 16K Gooseneck
Problems: None
Mods: None
Other: Mostly Desert Mountains, Off Road 3-10% Rock Grades
diirk Feb 11, 2004 10:17 PM
Thanks guys, this is what I'm looking for. I'll compile it into something cohesive when the replies slow down.
Keep em coming!!!
i6DZUL Feb 11, 2004 11:05 PM
Year: 03
Model: 3500
Mileage: 4,600
Gearing: 4.10
Item Towed: 7,500 lb TT
Problems: None
Mods: None
JAXFL Feb 12, 2004 08:06 AM
Year: 2003.5
Model: 3500 Ext Cab SRW
Mileage:8K
Gearing:.3.73 4x4
Item Towed: 6000lb TT.
Problems: NONE
Mods:none
Other: On occation sliding it into reverse there is a hesitation (2-5 sec) but then seems to work.
Big Cat 295 Feb 12, 2004 09:11 AM
Year: 2003
Model: 3500 srw
Mileage: 16750
Gearing: 3.73
Item Towed: 32ft 5th wheel
Problems: None
Mods: Intake
Other: Truck & 48re has been trouble free so far pulling 11,000 lbs. I am dissapointed in the exhaust brake issue. I waited to order the new truck with the 48re as it was advertised to be exhaust brake compatible. I attended the ATS seminar last Saturday in Denver and I will be knocking on there door if the stock tranny starts giving problems.
MAJORCOMMOTION Feb 12, 2004 09:39 AM
Year:2003
Model:2500 Quad 4x4
Mileage:14000
Gearing:3.73
Item Towed: 7000 lb TT
Problems: Zero
Mods: EZ & AFE PG7
Other::D
ppsi Feb 12, 2004 09:56 AM
Funny this comes up> I spoke-w-a very reputable and honest tranny guy this week and showed him my new toy. He rolled his eyes when I said 48RE and said he does at least one a month. Mostly on Rams-w-Gas. He said the 48RE is a "glorified"Mopar 727. He said the main cause for melt down is fluid temps and that there is a check ball in the line that sticks and causes no fluid circulation to the rear of the tranny. For the heck of it he looked at mine and was really suprised at the improvement they made regarding the line size and the size of the cooler which he said was huge.
FWIW-please give me some input. I plan on "bombing" this truck as soon as funds allow. I cannot imagine going back to a gas daily driver.
Also if there are easy/cheap/effective mods to the 48RE please advise me. - Thanks
fanofthewolf Feb 12, 2004 10:12 AM
Year:2003
Model: 2500 SO 2WD Quad short bed
Mileage:17,000
Gearing:3.73
Item Towed:7000 5th wheel
Problems:none
Mods:larger air box opening
Other:love it so far
Patrick Campbell Feb 12, 2004 10:49 AM
I dont think gas rams get 48re ??? I thought they get that 5spd auto with the HEMI.
