Stutter while RPM drop
I noticed for the last few weeks that there is a stutter or misfire when the truck drops to idle RPM. Common Rail pressures are within spec. I am seeing no codes with very little smoke coming out the back. Could this possibly be a bad or clogged injector?
2004.5 Dodge Ram 3500 Stock. |
Does your misfire happen only at idle or does it carry up into the RPMs then clears up?
Does the problem remain when the its in Park or N? |
