Strong Oil smell???
Strong Oil smell???
ok, once my truck gets up to running temp... i can shut it off, and when i get out, i can smell a hot oil smell from the motor, or when iam driving and i got the AC on with windows up, i can smell it through the AC....what could this be? someone said it could have a oil leak on the valve cover..???? iam takin it to DC monday to check it out..
Valvoline Premium Blue, Chevron Delo 400, Amsoil...from what I hear all of those don't have the oil smell that Rotella has. But I am pretty sure that the only one of those oils that out PERFORMS Rotella is the Amsoil and it's expensive. I just bite the bullet and deal with the Rotella smell until it goes away because I know that I have good oil in my engine...
On another note...can you visibly see any leaks?
Does it hurt anything to change brands I've always been a diehard Rotella Fan but you guys got me thinking about Dello. Ive been running Rotella for
16k in my 07 is it OK to change ? What weight do you run in the Dello still 15-40?
I have gotten that smell on Rotella, Valveline Premium Blue, and Amsoil 15W40synthetic. It's normal. The smell is coming from the vent tube from the valve cover. Nothing like the smell of a diesel after you have worked the pudding out of it. An that is what I mainly use mine for. I would never go back to a gas engine. Towing with this truck is a blast...
I use Amsoil 15W40 in my truck and I get the oil smell occasionally. I can only smell it when I get out of the truck and it is usually after working it pretty hard. I use the same oil in my tractor and when I work it really hard I can smell the same smell.
Has any one tried the New rotella suposed to have a higher flash point and greatly reduce ash?????????
Before to long everyone will be forced to use the CJ4 as it's backwards compatible anyway, but loses some add pack mainly because of particulate filters in the new low emissions diesels. Delo 400 also has the CJ4 API oil now.
None whatsoever.
You're referring to the new CJ4 formulation. Unless you have the 6.7 with the emissions equipment, stick with the CI-4+ API spec.
They already have stopped making the older CI-4+ Rotella oil as far as I know. I was trying to find some but went ahead and put in the newer CJ4 formulation. I can't tell any difference in it other than the label on the bottle.
I didn't notice any "smell" from it though, on my last oil change. Even on the older blend I only noticed a smell maybe every other oil change and for just a couple of hundred miles or so.
