stated motor wiht out valve cover on
no. 5 injector i s shooting diesel into the motor I have f1 injectors can i but just 1 I need my truck asap for work. thanks. thanks for all the help and thanks to spooler for this idea.
Yes, you can replace just the one. To be even safer, replace the connecting tube as well.
I will, do u or anyone know where I would be able to buy 1.
If your needing one in a pinch, dealer is the closest one. Though your going to spend $625 on a reman.
ouch I hope there are others out there thanks.
If you already have F1 injectors the tip is not going to match. Give one of Don's venders a call (who you used before) and see if they can help you out in this pinch.
thanks again I will give it a try.
