Speedometer correction
Old Apr 5, 2003 | 03:18 PM
crabman's Avatar
Re:Speedometer correction
The dealer can make the change to 3.73, saw the setting there myself when I was trying to see if I could adjust the tire revs enough to cover the tires.
Old Apr 7, 2003 | 07:30 AM
bulabula's Avatar
Not sure about DC, but I believe in some ECMs you can change the tires' revs/mile setting to accomodate bigger or smaller circumference tires.
Old Apr 7, 2003 | 08:52 AM
crabman's Avatar
There is a setting for tire revs but the window is to small to correct for the BFGs.
Old Apr 7, 2003 | 11:27 PM
crabman's Avatar
Yes, you just need to find a dealer that is willing to make the change for you. I meant the setting for unknown diff and tire revs does not give you a big enough window. I already tried.
Old Apr 21, 2003 | 12:50 PM
bulabula's Avatar
I wonder if DC would have a different ECM for the different gearsets where the ratio is burned-in the PROM rather than being able to be re-set? I doubt it, but you never know.
Is there only 1 part number for an '03 CTD ECM? Or 1 each for the HO and SO? Or 2 to accomodate the different gear options?
Then again, just because he couldn't find it doesn't mean it isn't there. For some arcane reason, maybe you cannot just enter in 3.73 or 4.10; maybe there is another "code" to enter and a look-up table enters the appropriate gear in the window. Something like an "a" for regular 3.73 and "b" for 3.73 Anti-slip? and a "c" and "d" for 4.10? Not that AS should make a difference.....
Just thinking out-loud.
Old Apr 21, 2003 | 03:01 PM
The Boss Hog's Avatar
Let me offer another possible explaination. There is no way to change the &quot;code&quot; in the ECM because it changes itself! It does this by sensing tire rpm via the anti-lock brakes sensor. Let me explain. I had a '93 F-150 that I changed the gears from the stock 3.55's to 4.56's. I then took it to a speedo-shop and the mechanic was surprised to find it already very close. But when I then added the tall tires, it read way slow. I don't know if DC works the same but they might.<br><br>The Boss Hog<br>(9600 miles and stronger all the time ;D)
Old Apr 22, 2003 | 12:13 PM
Mexstan's Avatar
Perhaps you guys who are talking to dealers etc about speedo correction can find an answer I have asked my dealer and they can't answer. My speedometer is in MPH but down the road I hope to be able to obtain a panel out of a wrecked '03 that is in KPH. My question is: Once I change the panel do I have to change anything else to ensure accuracy?
Old Apr 22, 2003 | 11:33 PM
Hunter's Avatar
Hmmm, go to a Speedo shop with a dyno, and have them put it up, and then change the spline into the tranny? Always worked for me before<br><br>Hunter
Old Apr 23, 2003 | 06:22 AM
Hunter,<br> I agree, that was the correct way to do it and worked great on my '69 Road Runner ;D. Unfortunately, that all went away with the dawning of the age of computers :'( You woun't find any mechanical spline (gear) to swap out in any new vehicle I'm aware of. Then again, I could be wrong <br><br>The Boss Hog<br>(basking in Florida)
Old Apr 23, 2003 | 12:47 PM
RickCJ's Avatar
Yes that can be changed. You have to go to the antilock brake area of the DRB and then change the tone ring teeth number. It is a 5 min. job if you can find any one sharp enough to do it. Good Luck.
