soo long to warm up why???
Old Oct 31, 2005 | 04:45 PM
motrapper's Avatar
it seems to take twice as long to warm up as my powerstroke did any good reason
Old Oct 31, 2005 | 05:05 PM
RamWheelsBy4's Avatar
Runs more effeciently than a PS.
Old Oct 31, 2005 | 05:08 PM
MikeyB's Avatar
I have found that skip shifting will help decrease the warmup time. Makes the engine work a little harder.
MikeyB
Old Oct 31, 2005 | 05:42 PM
Geico266's Avatar
Plug it in.
Old Oct 31, 2005 | 05:48 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
Originally Posted by Geico266
Plug it in.
Well said!!!
Old Oct 31, 2005 | 07:31 PM
LCH's Avatar
LCH
Plug it in.
I couldn't agree more, makes a huge difference. Plug it into a timer and set it to come on three hours before you leave for work, and get a winter front, Dodge makes the best looking one. Lists for $118.00 but can be had for low to mid 90s. LCH
Old Oct 31, 2005 | 07:55 PM
Muzzy's Avatar
I work about 8 miles from home, mostly highway. I plug mine in and it barely makes full temp by the time I get to work. Even in the summer time it takes a while. Just too good of a cooling system and oiling system. I am sure it doesn't help running synthetic oil too.
-Muzzy
Old Nov 1, 2005 | 05:32 AM
nickleinonen's Avatar
which year psd? the 7.3's from 99-03 had a butterfly valve in the exhaust [turbine outlet elbow] that actuated closed to load the engine [like having an exhaust brake on] to help with warm up...?
Old Nov 1, 2005 | 07:53 AM
Blue600's Avatar
No exhaust backpressure valve on the Cummins.
Old Nov 1, 2005 | 08:37 AM
bigblock2stroke's Avatar
You could buy an exhaust brake. It'll warm up in less than half the time. Or by the Espar coolant pre-heater.
Old Nov 1, 2005 | 08:52 AM
1sttruck's Avatar
It sems to take about 10 miles to get mine up to temp, which doesn't seem out of line for a 1000 lb or so engine.
Old Nov 1, 2005 | 09:43 PM
possum's Avatar
bigbblue just said an exhaust brake aids warmup time. I had not heard that before, Zatso? good to know!
Old Nov 1, 2005 | 11:34 PM
dodgezilla04's Avatar
my pacbrake will come on either when I take my foot off of the go pedal with the truck still rolling(decel) and when the water temp is below 170*. definately aids in warmup. that is the design of the pac, dont know about the others.
Old Nov 1, 2005 | 11:40 PM
Bluedeviltorque's Avatar
Anyone have the part number for the Dogde winter front? I mentioned it to my local deal one day this past summer and he looked like a deer in headlights and couldn't even find it on the computer. At least I know they exist, i've seen photos somewhere on here. Needless to say I don't deal with that dealer too often.
Mike
Old Nov 2, 2005 | 06:22 AM
robert chilton's Avatar
Try to keep your RPM up a little higher. Mine actually warms up 2-3 times faster than the 95 if I keep the RPM close to 2000RPM. If I am coasting in traffic the truck seems to warm up tommorrow instead of a few minutes. Give it a try.
