| rick83864 |
Jun 7, 2010 05:54 PM |
Something shakeing when taking off
Maybe someone can point me in the right direction. 06 Ram 3500 DRW auto 4x4 with 44k miles. About 20k miles towing 13500 lb 5th wheel with 3300 lbs pin weight. Truck has pulled this combination perfectly until last trip a couple of weeks back. It is hard to explain but there seems to be a shudder effect I believe is coming from the rear end. It almost feels like the wheels are breaking loose on gravel. It only happens at very low speed when accelerating and is gone by the time second gear hits. The truck squats about 4” when hitched up. I tried to search it and saw a few tranny threads and a possible drive shaft u-bolt problem. Sure hope it’s only the u bolts. Transmission oil was changed once at 30k ready to have it done again. (by the way, would you let a Dodge dealer adjust bans?) Truck only does this when pulling the RV.
Thanks for any help.
